ImPasse Preamplifier
Old 30th March 2013, 03:54 PM   #541
6L6 is offline 6L6  United States
6L6's Avatar
I have 2 transformers that could work - Which do you think would be better?
Both are not ideal - the potted one is a little shy on voltage, the Hammond has no filament CT...
I just noticed this about the potted one - if you look at the schematic, and the pins confirm it as well, the CT of the HV and the filament is the case... That's weird...
Old 30th March 2013, 04:03 PM   #542
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Top one has a case shield which is useful -- the Allied Transformer SY used Allied 6K3VG also had one.
Old 30th March 2013, 04:21 PM   #543
6L6's Avatar
And the fact that the CT of the HV and FIL windings is that same shield is no problem? I ask only because I haven't seen that before.
Old 30th March 2013, 05:02 PM   #544
jackinnj's Avatar
If it's potted then there's be no way to disconnect it!
There are other ways to get the filament at the potential necessary.
Old 21st May 2013, 08:57 PM   #545
6L6's Avatar
Coming along nicely. More parts on order.
Old 21st June 2013, 06:27 PM   #546
6L6's Avatar
Im needing to make one more order to get all the parts...the local electronics surplus has most of the stuff, but I still need to fill it out.
A couple questions,
What voltage NE-2? I'm not sure if the ratings are the strike voltage or max operating...
Is there any issue using a stepped attenuator? I have a 100K noble that I'm planning on using, but I'm still curious...
Are there any 'gotchas' in building this? Anything not obvious?
Old 21st June 2013, 06:30 PM   #547
On Hiatus
SY's Avatar
Neon is not critical, it's just for start-up protection- the lower the voltage, the better.
Main thing is to keep the bodies of the grid and gate stoppers close to the grids and gates. Otherwise, it's a pretty easy build.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st June 2013, 06:34 PM   #548
6L6's Avatar
Great!
Are the gridstoppers not in the ideal place on Jack's boards?
Old 21st June 2013, 06:38 PM   #549
On Hiatus
SY's Avatar
They could be closer, but I've built two of Jack's boards and they both worked perfectly. So I can't really complain.
Old 21st June 2013, 06:44 PM   #550
6L6's Avatar
I have another question that I just cant get my head around...
When running a F4 as mono you get 50W from a single-ended connection, but 100W from a balanced. The Rails are not any higher, and you have the same amount of PSU, so how can you get a doubling of power?
I'm sure with a good explanation it will become obvious...
ImPasse PreamplifierHide this!Advertise here!
Why do you need a preamplifier? globalweb Solid State 54 14th October 2007 04:47 PM
Mic PreAmplifier Ayne Solid State 4 13th April 2007 03:18 AM
Preamplifier aguantesoda Solid State 24 8th September 2006 02:39 PM
Preamplifier DIY Angel Puerto Solid State 13 20th July 2005 08:53 PM
Copyright ©1999-2017 diyAudio
