#521 |
If I remember, 10kHz square wave wasn't pretty.
I believe I have the FFT software installed, at least I can hit Math and select FFT for one of the channels and it shows up as a red line on the graph. So, what exact test setup would you suggest? Something similar to page 17 here: http://www.cs.washington.edu/lab/fac...s/71034901.pdf |
#522 |
I think I figured it out. I'm using 12.5k + 10nF as the zobel here. Using just 12.5k with no capacitor makes little difference in this graph.
#523 |
Also, one more question for SY when he gets back...
Why not just use a 10K attenuator and the 10K:10K transformer and not add anything in-between? |
#524 |
You can, and that will get you 95% of the best possible performance. But if you want it closer to perfect, you also have to consider the Miller capacitance of the tube and strays. I think you want to tune with a 50k pot and a 365pF variable cap. Or do what I did and tack solder a bunch of different parts in to zero in on the optimum values.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#525 |
... to be clear, you mean 50K || (12.5K + 365pF). I think for now I'll just stick the pot in and the 12.5K resistor and go from there and see how it sounds.
#526 |
#527 |
There was a slight 60 Hz hum when running amps with gain like the Aleph and F3 with my 95 dB speakers. I thought about using a regulator but the HT transformer voltage is just not high enough which means another transformer. Just not enough space in the case, so I ran the heater wiring through a bridge rectifier and CRC. With a 1 Ohm resistor the heater voltage came out to 6.25 volts. The 60Hz hum is now inaudible.
From an earlier post about noisy tubes, I tried a TUNG SOl 6SN7 and its working great. None of the EH6922 tubes have caused me any problems. BDP |
#528 |
yes!
In my case it was an overloaded isolation transformer Once rearranged my equipment it's dead quiet. Sorry for the slow response!
#529 |
You might want to try a ground loop breaker -- I use the one a la ESP --
#530 |
there is another thread here linking SY's article: ImPasse Preamp now online
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
| Why do you need a preamplifier? | globalweb | Solid State | 54 | 14th October 2007 04:47 PM |
| Mic PreAmplifier | Ayne | Solid State | 4 | 13th April 2007 03:18 AM |
| Preamplifier | aguantesoda | Solid State | 24 | 8th September 2006 02:39 PM |
| Preamplifier DIY | Angel Puerto | Solid State | 13 | 20th July 2005 08:53 PM |
| Page generated in 0.11964 seconds (80.69% PHP - 19.31% MySQL) with 11 queries |
