ImPasse Preamplifier
Old 30th January 2012, 01:10 PM   #511
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I will do a test tomorrow and see if light impinging upon the cathode LED's can modulate the output of the 6SN7.
Old 30th January 2012, 02:00 PM   #512
On Hiatus
SY's Avatar
I did that with a 12AT7 a few years ago and posted it. No effect, which is totally unsurprising.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 31st January 2012, 12:15 AM   #513
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
I think I have found my problem. I need more time to confirm...
Related Question: How do you determine if you have overloaded an isolation transformer? Is it total VA in each transformer divided by line voltage (perhaps with a fudge factor for losses and or headroom)?
My problem might be related to this.
Old 31st January 2012, 12:24 AM   #514
On Hiatus
SY's Avatar
One way to tell is when saturation causes the transformer to throw out an excessive 60Hz field!
Old 31st January 2012, 02:56 AM   #515
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
^or it is too hot to touch.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 31st January 2012, 05:38 PM   #516
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Max continous load of a smaller transformer is usually around 90% +/- of the VA rating divided by secondary voltage. Larger transformers ( 1kW and upwards) usually have somewhat higher efficiency. The real ( as in complex phase angles) wattage is always lower than the VA rating -There's always both core and winding losses......
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 5th February 2012, 07:30 PM   #517
luvdunhill's Avatar
I am planning on trying out my Sowter 3575 and am looking to tune the RC zobel to this transformer. First, it's not even close to the Cinemag values, much more capacitance is needed (note that this is a 10K:10K transformer, where the Cinemag is 15K:15K. I just realized that, and that fact might invalidate these tests?). So, what value would you choose (or what other values would you try). Datasheet:
http://www.sowter.co.uk/pdf/3575.pdf
Setup is Tek CFG280 (50 ohm output impedance, square wave of the Pk-Pk value show at 1kHz) into two wires of transformer primary, the sheild is connected to a secondary ground. There is a center tap, that I have just left loose (good idea? bad idea?).
Image #27 shows just 100K across the secondary, which represents my stepped attenuator (the last picture, sorry cannot reorder them).
Image #28 shows just 100K || 10k across the secondary, which represents my stepped attenuator in parallel with just a 10K resistor
Image #29 shows (6.8nF + 10K) || 100K
Image #30 shows (10nF + 10K) || 100K
Image #31 shows (16.8nF + 10K) || 100K
Old 5th February 2012, 07:46 PM   #518
jackinnj's Avatar
While it's nice to eliminate the ringing, you have to, at the same time, be mindful of what compensation capacitance is doing to the bandwidth of the amplifier -- were the oscillographs you show done with the preamp "live" ? -- as you have to deal with the tube capacitances which affect BW. I tuned my pre with a 2x365pF variable capacitor -- and found that it was find without any compensation.
Old 5th February 2012, 07:58 PM   #519
luvdunhill's Avatar
Nope, not live. I assume you still put a resistor across the volume pot in magnitude to result in the secondary inpedance of the transformer? I could definitely do it live I guess, but measuring bandwidth would be tricky as I don't have all the bits and pieces ready to do that. Good points of course, I appreciate that.
Old 6th February 2012, 01:35 PM   #520
jackinnj's Avatar
Then try using 10kHz as the fundamental, rather than 1kHz.
You can use one of the freeware FFT/soundcard programs -- or get the little FFT plug in module for your scope. The new line comes with FFT built in , but the older ones (I have a TDS3012B) need the TDS3FFT.
ImPasse PreamplifierHide this!Advertise here!
Why do you need a preamplifier? globalweb Solid State 54 14th October 2007 04:47 PM
Mic PreAmplifier Ayne Solid State 4 13th April 2007 03:18 AM
Preamplifier aguantesoda Solid State 24 8th September 2006 02:39 PM
Preamplifier DIY Angel Puerto Solid State 13 20th July 2005 08:53 PM
