ImPasse Preamplifier
Old 5th December 2017, 01:13 PM   #1111
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Kevin,
Thank you for your explanation. Part of my education from this project is the variability of tubes. I will get the plate - cathode voltage in the correct range, not sweat my measurement problems, and try different tubes.
Thanks again.
Jac
Old 16th December 2017, 08:37 PM   #1112
drpro is offline drpro  United States
A question for those that have used one of Jack's board's. I am finally getting to the stuffing stage of assembly. There are two cap position, C106 and C107 directly above the 6SN7 socket. They are not on the BOM. What value if any goes here?
David
Old 16th December 2017, 08:59 PM   #1113
mrdave45 is offline mrdave45  United Kingdom
I think they're 0.01uf 600v ceramic disc, probably x rated (although I don't think they have to be, probably just because 600v caps are often like that) they're decoupling on the elevated heater supply, have a look here:
The ImPasse Preamplifier
F4, Impasse, His masters noise, Troels Gravesen OBL15 and a stack load of analogue synths.
Old 16th December 2017, 09:56 PM   #1114
Thanks Dave. Got it now, page 14.
Old 17th December 2017, 02:30 AM   #1115
Another couple of questions from folks using Jack's boards. Referencing Jack's board, where does one connect the 6.3vac heaters? I think I would connect at the two side by side holes at the top of the 6DJ8 between R11 and R25. Just want to confirm.
Since the Allied transformer in the original build is no longer available I went with a Hammond xformer (272X). It does not have a center tap 6.3vac. Just 6.3vac on two wires. Will using this cause me difficulties? or ........
David
Old 17th December 2017, 08:00 AM   #1116
You won't be able elevate the heaters without the centre tap. This will most likely result in more noise and/or hum. I'm not sure whether the design requires the heaters elevated to avoid damaging the tubes. Some designs you do need this other not. If you get hold of a 2x3.15 tx (wire like a dual rail supply and stick the elevated supply on the 2 wires you connected together, this is now your centre tap) or 6.3v ct tx of suitable current you could use that instead just for the heaters.
Old 17th December 2017, 08:28 AM   #1117
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Why can't you elevate the heater without center tap? Just connect one of the heater sides to the elevation voltage.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 17th December 2017, 08:29 AM   #1118
jan.didden's Avatar
David
Can't you just do a continuity check with the DMM between those points and the tube socket heater pins? Rather than trust a reply that may or may not be correct?
Jan
Old 17th December 2017, 12:37 PM   #1119
I think the heater supply wants to be balanced for emi suppression and connecting one side would send this off kilter. Check this page out
The Valve Wizard
It looks like you can create an artificial centre tap.
Old 17th December 2017, 12:51 PM   #1120
jan.didden's Avatar
The Valve Wizard
That depends on a lot of things, for example the heater inside the tube may or may not be symmetrical against the cathode.
Anyway, there is no reason a non-CT heater winding cannot be elevated and that was the issue.
And, as you say, you can always create an artificial CT with a pair of low value resistors.
Jan
ImPasse PreamplifierHide this!Advertise here!
Why do you need a preamplifier? globalweb Solid State 54 14th October 2007 04:47 PM
Mic PreAmplifier Ayne Solid State 4 13th April 2007 03:18 AM
Preamplifier aguantesoda Solid State 24 8th September 2006 02:39 PM
Preamplifier DIY Angel Puerto Solid State 13 20th July 2005 08:53 PM
