Old 12th January 2009, 11:48 PM   #1
NV&H is offline NV&H  United States
Default F5 Power Supply Caps Seem Small
I'm speaking without knowledge here, but the capacitors that Nelson uses for the raw ps in his F5 strike me as very small. Is that because it's a Class A amp at low power where average current doesn't change? Seems that once it began operating in Class AB mode, ps voltage would start to swing around a bit. Is that not true?
If so, would larger caps help? Any downside to that?
NV&H
Old 13th January 2009, 12:20 AM   #2
gary s is offline gary s  Australia
Nelson's design is 60,000uF per rail for the F5.
For 25 Watts Class A into a load that can go down to 1 ohm without misbehaving as Nelson so eloquently puts it, means the PSU is more than adequate.
Nelson has always been known to have beefy PSU's in all his amps.
It will not hurt at all to build your own F5 with more capacitance, mine has 100,000uF per rail and sounds so powerful and in control at all times.
Cheers
Gary..
Old 22nd January 2009, 07:23 PM   #3
The caps don't have to be as large on Class A amps because they have a bias current and so the average current doesn't really change much?
NV&H
Old 23rd January 2009, 01:41 AM   #4
The one and only
Nelson Pass's Avatar
Depends on how you look at it. The large quiescent current creates
large ripple so you see more supply issues there. On the other hand,
these same supply issues arise under high power conditions with
Class B or AB.
This is DIY however, and over-the-top capacitance is part of the
landscape because it's not that expensive and there is little
controversy over the benefits, especially CLC or CRC.
Small Power Regulated Power Supply teleman Power Supplies 54 8th January 2010 11:19 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
power supply caps MikeZ Pass Labs 1 19th April 2004 02:02 PM
Power Supply Caps effindi Tubes / Valves 31 17th November 2003 05:27 AM
Power supply caps Ellen Parts 4 4th July 2003 02:11 AM
Page generated in 0.06412 seconds (76.59% PHP - 23.41% MySQL) with 10 queries
