I'd like to try converting the S/550e class A/AB to an SA/4e class A.
My understanding is that it's easy to do. These amps are the same -- just different power supply voltages and bias settings. I have an operating manual for the S/SA series. I know the values for the inital bias settings for the SA/4e and that's easy to do. I don't know the required secondary output voltage for the transformer or the power supply. Could someone share: 1) Which secondary taps to use & the desired PS output voltage? 2) Confirm that the bias settings & PS voltages the only differences? I'm using this as a subwoofer amp and don't think I need all the power I've got. Not sure what the ohm value is for the subs but I'd guess I'd still be ok power wise. Thanks Barry |
#2 | |
The one and only
voltages and bias. I don't know that you have the same transformers for both, but if not, you can do is tap the primaries for 220/240V which will take the supply voltages down to about 1/4 the power and allow twice the bias. Worst case, new transformer.
#3 |
Thank you Mr. Pass! You are the one and only!
Kindest Regards, Barry |
| sa/12e or sa/4e or s/550e | jfrago | Pass Labs | 9 | 23rd August 2007 07:14 PM |
| Threshold S/550e Service Manual | Barry1 | Pass Labs | 10 | 24th May 2007 12:35 PM |
| Threshold S/550e Bias advice | Barry1 | Pass Labs | 0 | 28th April 2007 02:09 PM |
| Threshold S/550e Info | EchoWars | Solid State | 7 | 9th July 2006 06:03 AM |
| Threshold Fet 10 pc | mach.88 | Solid State | 3 | 21st December 2005 08:57 PM |
| Page generated in 0.08016 seconds (75.32% PHP - 24.68% MySQL) with 10 queries |
