The Pass Pub: The High-End Off Topic Thread
@seventenths interested in being able to turn on/off, in this case for the Aleph J.
If the 12V is constant, it's just like ZM noted. Simply a relay with a 12V coil and contacts rated for the load. A diode should be placed between the coil terminals (line to positive) and you're good. If the 12V is a pulse, you're in the same boat as those using a momentary switch. There are threads/circuits here, Rod Elliott's site and elsewhere as well as really inexpensive flip-flop modules on amzn etc. If you go that route, watch the contact ratings. If lower than necessary You can always throw a more robust relay with that output. Cheers
  • Thank You
Reactions: 1 user
Official Court Jester
Joined 2003
from my (limited) experience, I don't like anything Jadis
not so judging by SQ (meh) but by simple factor of me being totally and utterly exclusive - 12AX7 is having no place in any amp, at least if not used in some peculiar and novel way**
and that's not the case with Jadis
as fully chromed Harley Davidson
gimme Victory
**for peculiar and novel (sort of) one need to look at Tim De P. constructions, for instance
