Brutti, sporchi e cattivi
Yeah, did her several times (in my mind, but what not)
Iside is in a wheelchair nowadays, from cattivi to catturato in under 40
That's what bksabath's wife says when he gets home from work.
ya picodumb noninformed Ozzie
BK is on his way to 'Talian almost down under , wifeless
hope he'll sell that red ferrariwannabee and buy some decent 'Talian car**
**which automatically means - car is not decent per se
In that case, except for the car, bksabath is very brainy (ie wifeless)
Get rid of that car bksabath and get yourself one of these
https://www.youtube.com/watch?v=cRbVqlbppj8
That is taking Moi back a few years
Use to have a 50 cc Cabbalero whit a 22 del' Orto instead of standard 14
Also had special Cylinder sleeve and Pistons by the dozen
+ Talian Law at the time was one can ride at 14 and no number plates
Any way considering that is bout 30 years since I left the widow maker under a Bus I am much more inclined to get one of those instead
BTW episode 4 is out considering how lame ep.3 was...
we reserve the right to use frivoulus spelling trough out excet when letter P is missing due to be extremely Lazy
BTW episode 4 is out considering how lame ep.3 was... Wifey iz big fan of Vinyl... Will be keeping an eye out for runny nose....
Found an new amp that needed a home.... Pretty good update for all of the techo bs that needs updating nowdayz..... Now I will need to build up a few F5's to plug it into...
Marantz US | SR5010
past midnight
just came from workshop , had (late) dinner and enjoying in coffee
contemplating - should I try twin per side Tann driver arrangement in near future , or not ( on my Absolute WAF OB spks )
yeah , new xover , new baffle - with existing Tann lowered and another on top of it ....... now I see that frame will need some changes
whadya think - worth a hassle , or not ?
Tannoy Brute Force OB ….. now Absolute WAF Tannoy OB | Zen Mod Blog
past midnight
For sure worth hassle.... also add little piece of trim on top to match walls even better!
The jolly chap is supposed to having said that about his predecessor Admiral Harold Rainsford Stark when refusing to sail the cargoships over the big splash in armed convoys, becoming sitting duck targets to the german wolfpacks.
No garageshow today. Ignition timing seems ok now cause it jumps on start gas tho everytime I open the carb cups its peasoup inside. I refuse to tear them down, to many projects now so I'm just gonna keep emptying them and blow the nozzles (as I'm used to and letting them clean themselves.
Well, alot of fire it was, both from carbs and exhausts, but I didnt have time to film that. Manly sound also
4 is beterer
I don't want to start a new thread for this question I've got, so I'll just ask here:
In an actively biamped system with an (active) line level crossover (at ~2kHz), which Pass/Firstwatt amp for >2kHz would you pair with an F5 that's taking care of <2kHz?
The tweeter it'll be driving is a Morel ST 728. Judging from the impedance plot, the impedance at 2kHz is 6R and it's steadily climbing to 10R at 20kHz. It'll be connected with a 68uF series cap.
Suggestions?
Suggestions?
past midnight
Yes certainly worth the hassle
blurp!
Suggestions?
F3 probably most romantic sounding
- The Pass Pub: The High-End Off Topic Thread
