Old 4th December 2001, 09:37 PM   #11
panos29 is offline panos29  Greece
panos29's Avatar
Send a message via ICQ to panos29 Send a message via Yahoo to panos29
o.k, message received well and clear :-)
How can i post an image of my amp? is this possible over here?
Old 4th December 2001, 09:50 PM   #12
Panos, check the link below, check out Adding Images
http://www.diyaudio.com/forums/index.php?action=bbcode
Old 4th December 2001, 10:18 PM   #13
hifi is offline hifi  Sweden
this might not be my place but i believe NP have ansvered that question a number of times and the answer have always been 55c for the mosfets. (ie heatsinks the mosfets will run hotter)
btw u can use this formula
Temp = Peffekt(lamdacase + lamdajunction + lamda heatsinktoair)
and se the different temps the junction temp shouldent go over 100c and the limit for the mosfets is 150c then they die....a crude and violent death...or something ;-)
there is a older thread where this is better explained!
/micke
Old 4th December 2001, 11:06 PM   #14
jduncan is offline jduncan  United States
Send a message via AIM to jduncan
you have to be very careful in that last formula though to understand the difference between one, say, 200W point source of heat on a 20" length of heatsink and 10 20W heat sources spread out with 2" spacing on the 20" length of heatsink. These yield very different results so make sure you are actually calculating the correct data here.
Also make sure that you calculate power dissipation in each source (mosfet) correctly.
Old 5th December 2001, 01:35 AM   #15
yes!....i concur...i was only showing the basic formula to make a reference to the earlier thread...
/mike
Old 5th December 2001, 04:48 PM   #16
panos29's Avatar
Default Some pics of my amp for everyone
Following the link bellow u can see 3 pics of my alepph 3 clone, if anybody needs pcb i can also sent copy pics of it too.
Thanks again to all who answered or red my posts.
Panos
http://briefcase.yahoo.com/bc/panos2...c=bc%26.view=t
Old 5th December 2001, 05:58 PM   #17
the link didn't work for me
Old 5th December 2001, 06:16 PM   #18
yeah...me too
Old 5th December 2001, 06:19 PM   #19
panos29's Avatar
I hate that when it happens! it works fine to me and ! really cannot explain why! Anyway I just posted this to the gallery at passlabs too.
My appologies to all of u to whom the link is not working.
Panos
Old 5th December 2001, 06:23 PM   #20
panos29's Avatar
Let me try once more
KRK V88 Over heating problem Tom7227 Chip Amps 3 9th August 2008 01:49 AM
MOSFET heating problem PuppetMaster Class D 9 9th May 2008 11:44 AM
lm3886 heating problem aniruddha Chip Amps 11 19th January 2008 08:13 PM
Bizarre (over)heating problem in big amp Stuart Easson Solid State 13 23rd July 2004 01:59 AM
Aleph 60 bias problem explorer Pass Labs 9 1st April 2002 06:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
