Compact Single-Ended Class A Build - Page 3 - diyAudio
Old 23rd December 2008, 12:30 AM   #21
inspiribomb's Avatar
Send a message via AIM to inspiribomb Send a message via MSN to inspiribomb
Regardless of whether or not the CEC is Class A, let's get back on track.
Old 23rd December 2008, 12:30 AM   #22
And FYI, what you don't see are the heat sink on the other side of that board, and the fan that resides on the bottom cover. A lot can be accomplished with forced convection. Where is this 60 watts at idle claim? I must have missed that part when reading the website. I understand the math and appreciate the input.
Anyway, back to the original topic.
Old 23rd December 2008, 12:30 AM   #23
Ah, found the 60 watt minimum power consumption rating. Yeah, that's just not possible, never saw that before. Regardless, the amp sounds quite nice.
Old 23rd December 2008, 01:12 AM   #24
oh, BTW, there is one other amp design out there that I think would be great candidate to build-- it is the GR25. It is not single-ended, though. The A-75 is not single ended either, I kind of missed that in your original post. For that matter, the F5 is not single ended either, but I like these two amps better than the single ended amp that I built.
JJ
Old 23rd December 2008, 01:22 AM   #25
Formerly "jh6you". R.I.P.
Babowana's Avatar
Hahaha . . .
Are you a salesman of CEC, wearing a green mask? I hope you are a real diyer
Season's Greeting
Old 23rd December 2008, 04:23 AM   #26
Step one is to decide how much power you want.
Step two is to choose an amp that will deliver that power (this is where you are now).
Step three is to work up a parts list and start pricing things...this may involve starting over at step one.
Step four is to source the heat sinks. They're the hardest to get part.
Step five is to source the power transformer. A much less daunting task than four, but it can be a nuisance sometimes.
Step six...build the thing.
Step seven...listen.
Grey
Old 23rd December 2008, 04:50 AM   #27
The one and only
Nelson Pass's Avatar
Step 8 - repeat steps 1-7
Old 24th December 2008, 06:05 PM   #28
Thanks for all the help, folks. I've got a good idea of what I want to do now (Aleph 30), and will be proceeding with board layout. Once I get that figured out, I'll get some of the other fine details ironed out.
I'm looking forward to seeing and hearing the results of this.
Old 24th December 2008, 06:54 PM   #29
hifimaker's Avatar
Hi Aaron, PM me. I have a spare set of A30 boards.
-David
Old 24th December 2008, 07:50 PM   #30
T11 is offline T11  Slovenia
Its 5300 and 3300 amps that are a class devices. Low THD implies an AB or D class device in amp53...
I wait to hear what will be differences between this two amps (pass and CEC)
have fun!
T
Need Tube kits of above 75W Single Ended Class A amp pokerking Tubes / Valves 25 11th July 2009 05:19 AM
class A single ended darkfenriz Solid State 16 21st January 2005 07:22 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Copyright 1999-2017 diyAudio
