Old 25th April 2003, 02:57 AM   #11
Send a message via MSN to porfi4ever
Default Switch
Sorry , but my camera does not help to do that. Anyway thanks for your replay.
Old 25th April 2003, 03:12 AM   #12
trigon's Avatar
Just drill the hole like this
Trigon
Old 25th April 2003, 03:44 PM   #13
Cradle22's Avatar
Hi!
The simplest way to use such a switch (I have nearly the same on my P3A) is with a solid state relais. I use the (new) Finder 26.2.8.230 relais, you don't need any extra parts (the relais gets triggered with a short 230 V burst from your push button). With each trigger action, the relais switches (mechanically!) between on - off - on...
Normally all such relais still required an auxiliary transformer for the voltage burst to trigger the relais, but these new ones can be directly connected to mains...
I don't know if there is a 110V AC version of this relais...
And as for the LED I added a auxiliary winding to my transformer, and connected it with a single rectifying diode in series (not sure, if necessary, since a LED is a diode already...???).
Maybe this helps,
Arndt
A Sacrifice For Freedom
Meadowlark Blue Heron - lots of questions tuberube Multi-Way 24 21st July 2006 09:37 PM
Blue Diode as Power Indicator Panelhead Pass Labs 9 21st February 2003 08:10 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Copyright ©1999-2013 diyAudio
