Old 11th December 2008, 08:31 PM   #1
ROLIKOV is offline ROLIKOV  Israel
Default X-5 bias adjustments
I have replaced 4 mosfets and 2 resistors to the center channel which needed repair ( receive matched pairs from PASS LABS )
Look like the amp work fine now ,
Let me say that i am the second owner of this lovely unit , and i guess this was repaired before .
Then i went to re- adjust the bias voltage to each channel ,
When i measured the bias voltage at each of the 2 pins located at the sides of the amplifier ( for each channel ) - i measured around 50mV ... ?? i am sure , it is not a mistake .
However - when i looked at the service manual - it says that it should be adjusted to around 950mV . ( 0.95v at each 2 pins )
So i stated to adjust each channel to 0.95v , but after 2- 3 minutes , i felt that the heatsink gets very hot , and since i was afraid that it will damage the mosfets or other parts , i moved back the bias to around 55- 60mV .( as it was before to each channel )
Now i am not sure what is the correct adjustment . ( 0.95v bring the amp to be very hot ...
Can someone please suggest ?
Old 11th December 2008, 09:17 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
dunno exactly how these bias pins are arranged in your X5 but - if they're accordingly to Papa's X5 SM downloaded from his own ftp - these pins are across TWO adjacent source resistors
taking in account that you have 4 pairs of output in each X channel - 0V94 means ~ 1A per leg , so four times that , multiplying with 66V ....
grande drek . 4Ax66V = 264VA per channel ; 1320W of dissipation overall ;
OK- for start - divide that figure (940mV ) with 4 ; - so go for 220mV
set , then see - is it 1320W/4 = 330W of dissipation still too much for heatsink ;
one thing is certainly sure - Papa never goes above 55C (maybe 60C in summer ) on heatsinks .
thats 3-5 secs max with hand on heatsink .
I hope that Grand Joker will give you real answer .
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 11th December 2008, 09:27 PM   #3
Zen Mod's Avatar
Owner Manual from PL site sez that dissipation is arround 200W at idle
so - 200/5 = 40W per channel
so - 10 W per each leg
10W/66V = 150mA
150mA x 2 x 0R47 = 140mV across those pins
measure , just in case , with amp in OFF -- have you ~ 1R across these pins ;
if yes - set it to 140mV and enjoy ;
if heatsink temperature allows that ( hand burning test ) , increase it to real skin burning
Old 11th December 2008, 09:49 PM   #4
The one and only
Nelson Pass's Avatar
A 950 mV figure is clearly an error. Go by what you see on the working
channels.
Acoustic 160 adjustments llwhtt Solid State 0 28th April 2009 11:55 PM
D1 Volume adjustments hifimaker Pass Labs 11 19th October 2007 10:18 PM
bias adjustments raveenvijendren Solid State 8 11th November 2005 12:17 PM
Plate amp EQ adjustments? mike.e Subwoofers 7 7th June 2005 06:50 PM
trim pot adjustments walters9515 Instruments and Amps 0 26th April 2005 09:28 PM
Page generated in 0.08455 seconds (77.22% PHP - 22.78% MySQL) with 10 queries
