Old 16th January 2009, 05:54 AM   #101
steenoe is offline steenoe  Denmark
steenoe's Avatar
Did you check about Q5 and Q6? They are the only ones left (with Q2) that can be the cause. I assume that you did check all the tracks for solderbridges and scratches. A thin scratch can cut a track, and be hard to detect. Check the board carefully on the track side, with a magnifierglass. I have attached the latest component placement for the positive reg, and am sorry that it doesnt work yet. (R9 is deleted, and simply left out)
Old 16th January 2009, 07:09 AM   #102
Formerly "jh6you". R.I.P.
Babowana's Avatar
I have also checked replaced Q2, Q5, and Q6.
I have checked all tracks, not only using eyes but also using "beep" test with my DMM, for any possibility of "short" or "open". I have found no deffect.
Somewhat tired
Old 16th January 2009, 07:13 AM   #103
Babowana's Avatar
Looks untidy.
Too much soldering, desoldering and soldering, desoldering and soldering . . .
Old 16th January 2009, 07:55 AM   #104
steenoe's Avatar
Weird case. All of mine works, no doubt, but I am starting to run out of good ideas. Maybe its time for some weird ideas.
1) Try to lift one end of the output cap and see if that changes anything. I have seen those MKP's do weird things.
2) Try to apply a little voltage to the LED's to double check their polarity. (I know I repeat talking about the LED's ) Maybe a battery will do. D1's positive leg goes to R6/C4 and D2's positive leg goes to Q6.
3) The only part that differs from mine is the KSA733's, but I think they should work anyway. I can send you some BC556c's if you want them?
Old 16th January 2009, 09:26 AM   #105
no.
The LEDs should be forward biased. The +ve goes to the negative voltage side not the positive voltage side.
regards Andrew T.
Old 16th January 2009, 10:37 AM   #106
steenoe's Avatar
I think of the anode side, as the positive leg on LED's. Anyway, i just spotted that the small "A"'s on the component layout are wrong, thanks to what you said, Andrew. The anode side still goes to the connections I mentioned.
JH, you might want to try and turn the LED's around.
Old 16th January 2009, 12:05 PM   #107
Babowana's Avatar
I understand the symbol of diode, and Anode (p-region side) and Cathode (n-region side). I also understand how it should be foward biased. The anode is to be positive with respect to the cathode. LED has two legs. In general, slightly longer leg is the anode (say + to be connected) while shorter one is the cathde (say - to be connected). Trust me. My LEDs are correctly connected
I have removed the output cap (4.7uF). No cure . . .
I think I could find BC556 near hear. Anyhow, thank you very much, Steen, for your kind offer . . . If I think of your kindness, I have to find out what my error is and have to show you a good result . . . . . .
Old 16th January 2009, 12:25 PM   #108
Babowana's Avatar
Ah . . . by the way . . .
After Toolereg project, I'm going to start another shunt regulator as shown here. The Toolereg is however pulling my leg . . .
In the attached circuit, I'm trying to have a current limiter, reference voltage, sampling circuit, error detector, control element and slow start. I'm applying Papa's diy op amp for the error detector and the control element.
Do you have any opinion, advice, recommendation or criticism?
Do you think it's better for me to open a new thread?
Old 17th January 2009, 01:46 AM   #109
Babowana's Avatar
Back to Toolereg . . .
Just to see reaction, I have connected the unregulated 30V as shown.
  • D2 light on but soon off
  • Q2 smoked
  • Then R7 smoked too
I have immediately removed the power from the wall socket.
Hmm . . . I want to build Toolereg from scratch once again. I will start it now. As I have spent all KSA733, this time I'm goint to use KSA708 instead of BC556.
Old 17th January 2009, 05:56 AM   #110
Babowana's Avatar
I have just finished the second board.
I have done my best to avoid mistakes.
I have checked polarities of D1 and D2 very carefully.
I have replaced 1 x 9.1V zener with 3 x 4.3V zeners.
Accordingly, R4 has been changed from 8.2K to 3.6K.
Attached is the photo of the second board.
Page generated in 0.11020 seconds (78.20% PHP - 21.80% MySQL) with 11 queries
