Old 7th April 2003, 04:19 AM   #1
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Default SOZ DC Offset question.
I recently finished one channel of my SOZ.
Rails = 16V Vgs reading of 4.58 and 4.55 on the FETs
DC Offset after 1 hour of warm up .588 Volts !!
To lower the offset i put an 8ohm resistor in parallel with R5, like
Mr. Pass mentions in the SOZ article. This brings the offset down
to 38mV.
My question is, is it normal to see that much offset with Vgs
readings like i got above? Is there any penalty in fidelity from
paralleling resistors to achieve minimum offset? Should I try
harder to find two better matching MOSFETS?
By the way, i was listening to the one channel through a
Paradigm bookshelf speaker and it sounded fine... at what point
does DC Offset start to get dangersous/sound degrading?
The BOSOZ/SOZ combination was deadly silent - free of hum and
hiss - and this was as set up on the test bench! I feel i'm going
to be very happy with this combo Then when i get the bug
i'll try to X them.
Thanks for the help
moe29 (pics when i get them boxed up)
Old 7th April 2003, 06:28 AM   #2
Account Disabled
In my opinion, the tolerances of resistor values also affect the differential offset. The parallel resistors would play roles to compensate the tolerances, without payment to the amp’s performance.
The differential offset is known in general as acceptable up to 100mV. This small offset would not degrade the amp’s output character. It merely creates negligible offset of the speaker’s piston motion center.
JH
Old 8th April 2003, 07:54 PM   #3
The one and only
Nelson Pass's Avatar
No problem with trimming resistors to get low offset. Most of
the time it's the result of matching, but whatever it takes to
get less than 50 mV or so is just fine.
Old 12th August 2003, 05:14 PM   #4
I have 40mv dc offset in my SOZ. The mosfets are mounted on separate heat sinks. Would mounting them on the same heat sink(of the right size) lower dc offset too?
Thanks in advance.
Paul
Old 12th August 2003, 05:28 PM   #5
moe29's Avatar
i don't think thermal considerations have much to do with
DC offset in the SOZ. Matching the FETS is what gets you the
lowest offset.... 40mv isn't bad at all.
Question on DC Offset davodavo Solid State 17 19th July 2009 11:37 PM
DC offset question tschanrm Class D 9 23rd February 2006 02:32 AM
DC Offset Question dsavitsk Chip Amps 14 10th May 2005 11:52 AM
dc offset question? crippledchicken Solid State 4 7th April 2004 10:37 PM
DC Offset question wheezer Solid State 2 13th January 2003 10:30 PM
Page generated in 0.07965 seconds (71.77% PHP - 28.23% MySQL) with 10 queries
