Old 5th April 2003, 12:04 PM   #1
Default IRFP240 faliure? Help needed!
Hello,
A few days ago a recognized increased low freq. hum from my speakers. I cheacked basic parameters on boath chanals of my Aleph 2 monoblocks. All voltages on pcb`s are in service schematic limits (litle higher voltage on R19 on falied chanal - 4,8V acros R19), problem ocures on FET`s PCB board. On one of the fets, the voltage acros the source resistor, raised from normal 0,45V to 2V . All other fets (on + and - chan.) are runing at 0,52volts acros source resistor (cca. 0,45V before faliure). Temperature on heatsinks raised for cca. 2-3°C. There is a noticeable change in sound caracter as well, but boath chanals keep playing. Am I dealing with dead FET?
regards
Marijan
Old 5th April 2003, 11:23 PM   #2
I'd just replace the bad FET and see how it behaves then. If this is a new amplifier it may be that you just have a defective device. 2 volts across a source resistor is way too much. Also check it with no input. Perhaps your preamp is throwing out a tiny bit of DC.
Mark
Old 6th April 2003, 12:40 PM   #3
Thanks Mark,
it was a lost conection (desolderd joint during the heating of fet I supouse) betven source resistor and source pin on irfp. Everithinng back in normal now. I should go to P2P conection I think.
regards
Marijan
IRFP240 PSU... for dac lykkedk Pass Labs 4 3rd February 2007 02:36 PM
IRFP240's on E-Bay???? Mark A. Gulbrandsen Pass Labs 12 29th March 2005 11:10 AM
Irfp240 Please Any One!! jleaman Solid State 9 7th March 2005 08:10 PM
Irfp240 nbcd Solid State 4 30th April 2003 07:48 PM
Page generated in 0.06289 seconds (70.98% PHP - 29.02% MySQL) with 10 queries
