F Series First Watt Transformers
Old 19th November 2008, 11:16 PM   #1
hifimaker is offline hifimaker  United States
hifimaker's Avatar
Default F Series First Watt Transformers
I'm perfboarding an F1 and maybe an F2. Is a 250va 18-0-18 toroidal transformer undersized for a mono bloc for these amp types?
What would be the ideal VA rating?
Thank you!
-David
Old 19th November 2008, 11:36 PM   #2
gl is offline gl  United States
Hi David,
You're fine for a monoblock. Some might even consider 2 chans from that transformer.
Graeme
Old 20th November 2008, 12:11 AM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
VA ratings are a bit dicey. One manufacturer's 250 VA is another's
100 VA.
Old 20th November 2008, 12:20 AM   #4
hifimaker's Avatar
Thanks guys for the help.
I'm looking at an Avel-Lindbergh Y23 series. They have a 160VA and 250va in 18-0-18 at Parts Express with a free shipping special offer.
They seem like a good vendor and could probably assume the VA ratings are accurate?
-David
Old 21st November 2008, 01:02 AM   #5
GRollins is offline GRollins  United States
Avel Lindberg is all right in my book.
The thing about VA vs. Watts is that sometimes it's apples to apples and sometimes it's apples to elephant boogers. Setting aside the relative quality that you might expect from one manufacturer or another, the VA only equals W if the load is purely resistive. Once the load becomes reactive (not to be confused with radioactive), then you get into power factor correction. Depending on how far off the current and voltage peaks are from one another, you can get wildly differing numbers.
Grey
Old 21st November 2008, 01:33 AM   #6
preiter is offline preiter  United States
preiter's Avatar
Have any recommendations for choosing a transformer then?
I was also looking at the Parts Express transformers. Is the 225VA enough for an F4? The next step up is 330VA. They don't have 18-0-18 in that size, but I could get 35-0-35 and wire the primaries in series.
Old 21st November 2008, 01:54 AM   #7
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
I'm using 18-0-18 300VA covering both channels for F4.
I don't see any problem at all.
Old 21st November 2008, 04:13 PM   #8
SCD is offline SCD  Canada
Default transformers
I built mine with Plitron.
Very nice transformers. It runs cool and is dead quiet.
SCD
Old 21st November 2008, 06:38 PM   #9
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Default ANTEK
I use these puppies from ANTEK 18v+18v @ 400VA.
No problems with them. I think Nelson tested a members at one point and found them acceptable. They are fairly inexpesive.
http://cgi.ebay.com/18-18V-400VA-Tor...3286.m20.l1116
Old 21st November 2008, 06:39 PM   #10
hifimaker's Avatar
This is the best audio forum. Thank you so much for the guidance. I wish I could buy you all a beer.
-David
F Series First Watt TransformersHide this!Advertise here!
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 10 3rd August 2012 07:32 AM
Transcendar SE 5K 8 ohm 10 watt Output Transformers with UL taps nikolas812 Swap Meet 9 5th June 2009 10:51 PM
Bartolucci 300 watt output transformers wellerinhand Swap Meet 0 21st November 2007 06:51 AM
FS or Trade: 150 Watt Transformers john65b Swap Meet 2 2nd August 2007 04:20 AM
power transformers in series Jaap Tubes / Valves 10 19th February 2006 07:03 PM
Copyright ©1999-2017 diyAudio
