Old 4th April 2003, 03:20 AM   #1
Default 2.2mH inductor in Aleph3 Power supply
Hi
I am trying to find an inductor (cheap) to use for an Aleph 3 amp power supply (Kristijan's) design. I came across this on partsexpress.com and was wondering if I could use this. I looked at some previous threads on which inductors to use and it looks like a Metal core inductor is what Nelson suggested.
ERSE SUPER Q 2.0mH 16 GA 500W INDUCTOR Part number 266-904.
I remember someone saying the diameter of the wire for an Aleph 3 Power supply should be at least 1.4 mm which translates to 14 AWG wire. I am wondering if I should take the wattage of the inductor into account (500W is more than enough for a single channel Aleph3) or is the thickness of the wire important?
Does anyone have any suggestions to particular part numbers that I can use and where I might get them?
thanks
vsr
Old 4th April 2003, 04:41 AM   #2
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
http://www.zalytron.com/
claims to sell the Erse inductors with 14ga wire
Old 4th April 2003, 08:42 AM   #3
wuffwaff's Avatar
vsr,
I donīt know if itīs good to use an iron core choke because of saturation. (Then itīs only a resistor).
What you could use and what is also cheap is a 1.8mH air core choke with aprox. 0,4 ohms. I use them for my Aleph 5 and they work fine.
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 4th April 2003, 04:40 PM   #4
diyAudio Editor
Variac's Avatar
From what I remember, The Man (Nelson) recommends 14ga cored Erses, says they handle over 6 amps. On a balanced supply you need 2 per channel. They have the advantage of having less resistance than an air core inductor, and don't pollute their surroundings with as much of a magnetic field so in some ways are better
Old 5th April 2003, 12:21 AM   #5
Question Can I use
Thanks to all for replying. I looked at Zalytron and found the following metal core. I looked at the old Nelson Pass post and he recommended an Iron core and I was wondering of I can use the following?
14 Gauge Super Silicon Grain Orientated Steel Core Q Coil
thanks
VSR
Old 5th April 2003, 02:58 AM   #6
diyAudio Moderator Emeritus
roddyama's Avatar
If I recall correctly, this core has a bit of an air gap which makes it less suseptable to DC saturation then typical iron cores, as well as the other benefits Mark has indicated. Although, I have 2.2mH 12ga Solen air cores on the way for my Aleph 5. I'm just hard headed I guess.
Rodd Yamashita
Old 5th April 2003, 02:59 AM   #7
diyAudio Editor
Variac's Avatar
In this case I believe that "iron" was just a figure of speech
in the same way people call their transformers "iron"
He said Erse, so I'm quite sure you found the right ones.
Old 5th April 2003, 03:49 AM   #8
apassgear's Avatar
Judging ERSE Super grain oriented Coil by their DCR I'm sure you will get an open core. Not a closed iron like in a transformer. But no photo is shown.
Old 6th April 2003, 09:43 PM   #9
Tim F is offline Tim F  England
16 guage is 1.5mm
14 guage is 2.0mm if this helps
Old 7th April 2003, 08:13 AM   #10
Originally posted by Tim F
16 guage is 1.5mm
See also: http://www.vandenhul.nl/artpap/awg.htm
Is that all there is?
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Simple power inductor calculator Bootstrapper Power Supplies 4 26th March 2009 12:24 PM
Homemade Power Inductor??!?!?! alirezan Multi-Way 2 17th October 2007 10:20 PM
Output Inductor Power Requirement gearheadgene Class D 6 28th February 2007 03:47 PM
Aleph3 dumping factor and power JacekPlacek Pass Labs 8 5th July 2004 07:13 AM
Page generated in 0.09976 seconds (80.03% PHP - 19.97% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
