Came across these while searching the web for components and thought that they might be ok.
Since I however know absolutely nothing about "open-chokes", I searched here to see if anyone had used them and, naturally, nobody had.... So, whatīs wrong with these(?): Inductance 2,5mH, DCR 0,044, "Saturation current"(DC) 10 A. Price: 20$ a pop! (not that bad is it?) available here manufacturers info Cheers Mats |
#2 |
hi Mats,
there are some threads about those chokes... Uli ![]() PS: nothing wrong except size
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#3 |
I have searched for info but nothing about these chokes comes up.
I found one thread where you(Uli) said you used another choke from Hammond that was bigger, I think. Is this the same kind of deal except smaller? Cheers Mats |
#4 |
Hi Mats,
the point is that if you use cores that form a closed circle in some way, you should NOT apply DC voltage! The Hammond chokes (EI cores) have an air gap to solve the DC problem. You are free to use the cheapest choke that fits your bill (current handling capacity vs. DC resistance vs. inductivity) Uli
#5 |
I have searched this forum for references to the 159ZL (Hammond's 159ZL DC choke) and have found very little. I have also found a local supplier that carries them. So, my question is......would they be the ideal choke for Kristijan's design given their very low DCR? I'm very near to having all the parts for my Aleph 5 and the power supply is the most challenging part.
Regards, Dan |
#6 |
I am one of the least qualified to comment, but I would have thought that:
1. so long as your AC supply is high enough to take a small loss 2. the constant (DC) current rating of the choke is adequate This will be fine. Recall some people actually use RC filters in the supply rail by choice. This is a totally different scenario to a speaker xover where DCR is a significant problem. Given the cores are gapped & they are rated appropriately, I would suggest you go for it! regards mark |
#7 |
I've got several pairs of inductors left from various I made with good iron cores, they are gapped for 3.5 to 6 amps.
I'm actualy using a pair of these gapped for 3 amps with 16 mH on my Aleph 4 with excellent results. The general spec for these are: Iron: Silicon laminations M-15 Size: EI 100 Inductance: 10 to 14 mH DCR: 0.05 Ohms Amps: diferent gap for 3.5 to 6 Amps Finish: Metal bracked and varnish dipped. I will post a photo. Anyone interested please contact me. |
#8 |
Photo of undipped inductors:
| Caps/Inductors for a Filter | hammdawg | Parts | 2 | 13th November 2007 06:51 PM |
| HF filter inductors for signal path | cathode_leak | Tubes / Valves | 3 | 12th May 2005 09:32 AM |
| Looking for Inductors for use in Pi filter | vsr123 | Swap Meet | 0 | 16th April 2003 12:43 AM |
| Optimum placement of inductors in CLC filter | rwagter | Pass Labs | 4 | 18th November 2002 09:59 PM |
| Page generated in 0.09819 seconds (79.09% PHP - 20.91% MySQL) with 11 queries |
