Hi all,
Today, I tested my A2 pcb's on a 1/6th scaled down test rig. For power, I used 2 lab bench power supplies set at 54V 1.5A, and in stead of the high power output stage (the part in the schematic which is multiplied by 6), I used a temporary setup using only 1 pair of fets. (So current drawn by the circuit was just over 0.5A) The load was a single 10 ohm power resistor. The circuit runs perfectly. I have the mosfets in the differential stage matched up to <10mV, as well as all other semiconductor devices. At first measurements, there seems to be very little channel imbalance between the two PCB's Still there is an issue. There appears to be a large transient when switching on and off the amplifiers. I have attached a scope screenshot from the OFF-thump, which was the worst one compared to the ON-thump. I am not sure what causes this thump. Of course it could be the setup, since the two lab supplies were not linked, and the two power output devices were not matched at all. Or perhaps is this behaviour normal for Aleph Amps? Or should I look for an error in the pcb? Thanks, Bouke About the screenshot: Yellow trace: Positive Supply Rail Blue trace: Negaive Supply Rail Pink Trace: Output Voltage Green trace: Output Current
More Power Igor! More Power! |
#2 |
This is the ON-thump. It's slightly more benevolent than the OFF-thump, but also takes longer to diminish
The screenshot: Yellow trace: Positive Supply Rail Blue trace: Negaive Supply Rail Pink Trace: Output Voltage Green trace: Output Current
#3 |
And for reference: a picture from the test setup, not showing the bench power supplies.
Note this is the first public picture from my amp in progress... WARNING! May contain audio adult content
#4 |
Alephs are generally sensitive ( regarding thumps ) only on amount of capacitance in parallel with zener diode , which is in biasing part of input LTP CCS ; if you stay with Papa's prescribed values for that cap , everything is fine
I resume that you have problems with different time constants in your two independent supplies ppl use these dreky amps even for Lowthers and similar "fragile" spks .... that tells something ....
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#5 |
That was what I was expecting yes... As you may see in the OFF-plot the negative rail does not come down to 0V immediately as the positive rail does.
I think I'll have to do the test once more when I have it connected to the intended Power Supply. Thanks, Bouke
#6 |
you'll know more (regarding actual PSUs ) if you swap them between + and - leg
#7 | |
The one and only
#8 | |
What is typical about the screenshot?
#9 |
The thump is normal. It is to be expected.
Grey |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Aleph-X smaal EU "small-parts" groupbuy | Sander | Group Buys | 3 | 3rd December 2008 11:48 AM |
| Turn on/off thump with "others" D amps...how it is managed? | pat allen | Class D | 11 | 16th March 2005 07:58 AM |
| Aleph "L" Stepped attenuator on the input or the output? | Mark A. Gulbrandsen | Pass Labs | 6 | 13th March 2003 12:21 AM |
| Is it normal "not" to have any turn on thump? | Duo | Solid State | 23 | 7th September 2002 05:45 PM |
| Page generated in 0.11338 seconds (79.30% PHP - 20.70% MySQL) with 11 queries |
