#11 |
are you saying R1 to source of Q2? because the diagram i saw on the passdiy zen amp shows gate of Q2 going to R1
both of the drains are connecting from both fets i am using 140's not 240's juat so we are on the same page |
#12 |
The one and only
0 volts on the Gate of Q1 means no bias for Q1, and explains a lot.
What's happening with the resistors from Drain to Gate and Gate to Ground? Is the input cap in place? Is the Zener backward or shorted?
#13 | |
Yes, that's what I'm getting at. If you look at the schematic, you'll see that it's the source of Q2 that's connected to R1. The pinout of IRFP140 and IRFP240 are the same. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#14 |
gate to ground is 0 ohms or a direct short. the zeners are pointed towards the power input side of the board. when probing between drain and gate of Q1 the resistance 20k plus and keeps climbing
#15 |
By coincidence, I just helped a friend of mine sort the same problem out, and I made a pic, after I had written the correct connections.
Magura
#16 |
holy crap i think i flipped all the fets the wrong way. mr pass if you could take a close look at the pic i posted i flipped the gates and sources of all fets. was that a mistake? i thought i would need to because of the direction i mounted the mosfets
#17 |
wow thanks for the help guys. im going to flip these fets and see what happens.
what direction is the safest bet on the pots on first power up? |
#18 | |
Just set the pot in the center position, it really makes no difference. If you have not already replaced the 0R22 with 0R33, do so before you power it up, as I suspect you're gonna run out of heatsinking pretty quick if you don't. Magura
#19 |
#20 |
Now to spare yourself a few blown parts, make sure you have the source of Q2 is connected to R1.
Note: The fets are not mounted the same way on both channels. Magura
| Help Needed!! Tubescreamer build; Pot noise problems | eviljoe | Instruments and Amps | 5 | 10th February 2008 08:43 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| eti 480 build problems | aquasync | Solid State | 15 | 14th February 2005 01:17 PM |
