F1, 6SN7 to AudioNirvana 12"...  Mr.Pass
Old 4th November 2008, 11:31 AM   #1
khundude is offline khundude  Canada
Default F1, 6SN7 to AudioNirvana 12"... Mr.Pass
Hello Mr. Pass and all. I read of your love for certain triodes and with you experience with the F1 and the AN drivers, so any help would be appreciated. I am in the process of building an Aikido preamp with a 6SN7GT or 7N7 driver tube and 6N6P for the buffer. The source is Twisted pear Buffalo DAC with the D1 I/V stage which will need to be adjusted.
1)Will the 6SN7GT(gain of 10) provide enough gain to drive an F1/AN Cast super 12" from a two volt source with the AN12" in a TL enclosure.?
2)If the gain is not enough, can I modify the D1 to put out say, 4V?
3)What is your favorite driver tube? I like the 12SN7 for being a cheaper 6SN7. I think the high current of the 6N6P will follow the 6SN7 great fo a gain stage for an F1.
4)Could an F1 amp be made to drive a set of Senn HD650 by reducing the rail voltage?
Thanks for your time and I look forward to hearing of your time with the AN drivers.
Old 4th November 2008, 12:53 PM   #2
jeapel is offline jeapel  Canada
hi
6sn7 gain maybe 10 with a resistor to B+
but can jump to 20 with a ccs (constant current source) to B+
in my setup :
my tube preamp gain = 10
my power output aleph 3 gain = 10
total=100 it s ok for years now but
it s a minimum and for me the
maximum would be 200
bye
Old 5th November 2008, 01:21 AM   #3
MikeW is offline MikeW  United States
MikeW's Avatar
I have an Aikido (6SN7)with an F1 and 8 inch audio Nirvana and it works fine.
MikeW
Old 5th November 2008, 10:02 PM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Default Re: F1, 6SN7 to AudioNirvana 12"... Mr.Pass
I am not enough of a tube guy to have considered opinions of the merits of
various drivers tubes, but I'm sure that someone else will.
Yes, an F1 would probably be fine, even with reduced voltages.
Old 5th November 2008, 10:34 PM   #5
Default Re: Re: F1, 6SN7 to AudioNirvana 12"... Mr.Pass
Thanks for the info guys and Mr. Pass for the F1 nod... What would be a suggested rail voltage to run the F1 head-amp? Would be be possible to use the same F1 I plan on building for the AN12 with 2amps of current?
F1, 6SN7 to AudioNirvana 12"...  Mr.PassHide this!Advertise here!
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 4 9th July 2012 03:25 AM
FRANK"S 6SN7 preamp/linestage mosfets Tubes / Valves 88 16th February 2012 02:09 AM
schematic variation and sim results of Pass "X" series US pat 5376899 tiefbassuebertr Pass Labs 13 30th July 2009 09:33 PM
FS: AudioNirvana 8" FR Drivers ervington Swap Meet 3 17th January 2007 03:48 PM
