#11 |
Output between gnd is measured at 35.42V
#12 |
Its too much ...
(should less than 50mV) Same issue on both channel? Voltage accross R14 is near 0. You don't have any current going through it, no voltage drop; so lower output mosfets don't conducts hence you get plain rail voltage (- 35V) at the output. You could check if there is something wrong with R14 (to high res) and/or Check Q1 and Q2 You should have about 4 V Vgs. You could try to replace them, taking care of electrostatics ... Manu
Manu, masked agent of entropy & ZMs Čiko |
#13 |
I have canibalised the board, measured all resistors and zeners and re-soldered them back to a new board with new matched IRF 9610 and new MPSA18 transistors but the problem persisted. This is the measurement :
Output between gnd is measured at 43.3mV R14 at 3.528V MPSA 18 at Q4 measured at 3.525mV MPSA 18 at Q5 measured at 11.7mV R40 & 41 measured at 0.0 R42 at 0.7mV R22 to R25 measured at 0.7mV R11 measured at 5.12V R14 at 3.528V Z5 at 9.05V Q3 IRF between G and S is measured at 3.93V Q2 IRF between G and S measured at 3.79V Q2 and Q3 mosfet warms up but not Q1 When I measured Q1 between G and S, a buzzing sound is audible at the speaker when I touch the G of the mosfet Many thanks to those who help. |
#14 |
My PSU is modeled after Krijistan's Aleph 5 PSU.
Output at 38.8V |
#15 | |
Q2 from drain to source at 41.30 V Q1 from drain to source at 37.8V Q6-8 IRFP240 from drain to source measured at 37.5 Q18-20 IRFP240 from drain to source measured at 38.5V How do I measured the drain of IRF9610 to ground? Get the measurement from each IRF9610 between D and G from the star Gnd of PSU? |
#16 |
I am using 0.47/10 W for R22-25 and 1R/10W for R40-42 and R64-66
Would this be a problem? |
#17 |
I soldered R9 with a 220K resistor and R19 with a 220 resistor. Now when I turn on the amp, the LED lights up bright in a split of a second and then stay half dim. When turn off, the LED shuts out and then brightens up again with a very dim light. Also, when i turn on the amp, the speaker moves inwards and stay at that position. Thanks for help.
| problem with R44 on Aleph P 1.7 | Stefanoo | Pass Labs | 15 | 9th October 2007 12:57 PM |
| Problem with aleph p 1.7 | gabflo | Pass Labs | 7 | 2nd September 2006 05:50 PM |
| Problem with Aleph 2 | ppesa | Pass Labs | 1 | 31st January 2006 07:44 PM |
| Aleph 2 problem!Help... | nar | Pass Labs | 14 | 1st June 2003 03:42 PM |
| Aleph 5 PSU problem please help? | xsnailx | Pass Labs | 10 | 4th March 2003 06:28 PM |
