Aleph 5 problem
Aleph 5 problem
Old 30th October 2008, 05:00 PM   #1
pmchoong is offline pmchoong  Malaysia
pmchoong's Avatar
Default Aleph 5 problem
Hi all. I m in the midst of testing my Aleph 5 mono with Mark Finnis's pcb. When connect to the speaker (one channel) nothing seems to happen. When I switch off the amp, the LED stays illuminate for 20 minutes before finally dim. I matched the N fets according to a diagram by Kristijan. They are value at 3.03 to 3.20V. Is this possible? I used a 19V to a 150ohm resistor. The power from the PSU is measured at 37.75V. The speaker terminal measured at 0.07V. What is the problem??
Thanks in advance.
Old 31st October 2008, 06:54 PM   #2
kilowattski is offline kilowattski  United States
kilowattski's Avatar
The LED stays on pretty long because you probably have some monster power supply caps and no sort of bleeder resistor for the caps to bleed off the charge.
Kilowattski
Old 31st October 2008, 07:36 PM   #3
Jaac is offline Jaac  Netherlands
Jaac's Avatar
Seems like there runs no current at all trough your FETs. You can check if there runs current. You can measure the voltage over R11 it must be around 4 Volts. You can also see if the voltages are the same of each channel.
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 31st October 2008, 07:58 PM   #4
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Aleph 5 problem
Pictures are always welcome. Helps a lot sometimes.
In fact, by looking at the pics I posted in the Mini A thread, rtirion spotted the wrongly inserted Zener diodes my circuit. The Zener has to be orientated correctly to make the currentsource work.
So be sure to post pictures and check the orientation of the Zeners in the current source.
Gravity - Making the G since 13.7 billion B.C.
Old 31st October 2008, 09:02 PM   #5
pmchoong's Avatar
Right, I have some zeners reverse and the transistors are BC550, which has the CBE on the reverse as oppose to MPSA18. I have rectified these but problem persists. When I switch on the amp, the speaker moved forward and the lights are not on now. I have attached some pics. Thanks guys, i appreciated your help.
Old 31st October 2008, 09:03 PM   #6
pmchoong's Avatar
another picture
Old 31st October 2008, 10:36 PM   #7
hates ground loops
Rodeodave's Avatar
Aleph 5 problem
The cone moves out and stays there? Or does it move back again? And the lights are not on? If the lights are not on something might draw a whole lot of current and will cause the supply-voltage to drop. Not a good thing. In that case you should also hear a buzz from the transformer as the core saturates.
I hope you have some cheap test speakers...
We now need some numbers. Do you have the aleph 5 service manual? On page 6 there's the schematic with some voltages.
Please measure the DC voltage of the following points (take a look at the schematic):
- Voltage across the Zener and the source-resistor in the CCS
- Voltage across all the BC550s from collector to emitter
- Voltage across the output-FETs' source resistors and the FETs themselves (from drain to source)
- Voltage across the FETs of the CSS and the differential pair (also from drain to source)
- Voltage from drain of the IRF9610 in the CCS to ground
- Also please measure the supply voltages in reference to ground and the output-offset.
This should give some clues.
Old 2nd November 2008, 03:52 PM   #8
pmchoong's Avatar
zener (Z5) at Q3 - IRF9160 measured at 8.89
Z2 measured at 0.10
Z1 measured at 0.13
Z3 at 0.43
Z4 at10.26
Q5 - BC550 between C and E measured at 0.56
Q6 - BC550 between C nad E at 0.0
R11 measured at 5.29
R14 measured 0.0
Q1 - IRF9610 between G and S measured 0.5
Q2 - IRF9610 between G and S measured 0.53
All output resistors measured at 0.0
Old 2nd November 2008, 03:54 PM   #9
pmchoong's Avatar
How do I measure the gnd and the output offset? Is it between the star gnd and the output at the speaker terminal?
Old 2nd November 2008, 10:22 PM   #10
Manu is offline Manu  Europe
Manu's Avatar
Yes, DC offset : measure DC value just between your 2 output terminal + and - (star grd).
Manu
Manu, masked agent of entropy & ZMs Čiko
Aleph 5 problemHide this!Advertise here!
problem with R44 on Aleph P 1.7 Stefanoo Pass Labs 15 9th October 2007 12:57 PM
Problem with aleph p 1.7 gabflo Pass Labs 7 2nd September 2006 05:50 PM
Problem with Aleph 2 ppesa Pass Labs 1 31st January 2006 07:44 PM
Aleph 2 problem!Help... nar Pass Labs 14 1st June 2003 03:42 PM
Aleph 5 PSU problem please help? xsnailx Pass Labs 10 4th March 2003 06:28 PM
