#11 | |
Don't worry, so is he ![]() Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#12 | |
I want a output, simulair what you get after volcontrol before the input at an preamp, but i must attach it, at my output, due that my volcontrol is attached there at my BoSoZ... This output gives a TOO big voltageswing to drive my plateamp-sub's linein... So i have to make a seperate lineout, wich gives me max 3-4vac out, when volcontrol is turned up to MAX... !! Good enough ?? Jesper
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp. |
#13 |
take out from BOSOZ output , using just positive leg and ground ;
place pot (or just L-pad) in line , for attenuating simple - if that is what you need ( unbalanced to plate amps ) . with taking signal from preamp output , you have low enough impedance of taking point read few last pages in Cook Book ........ I wrote that .
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#14 |
Cool enough... i will study that cookbook ...
Jesper.
#15 |
Just a piccie... of temp. setup.
Jesper.
#16 | |
See, that's why nobody could figure what the problem was....there was no problem Magura
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Akai GX 265D line voltage on line outs? | ShorBird | Solid State | 11 | 26th January 2009 11:44 PM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Grounding thev Balanced line stage(BoSoz) | Amj_ciron | Pass Labs | 21 | 16th July 2002 12:22 PM |
