Line Out for highgain BoSoZ Line Out for highgain BoSoZ - diyAudio
Old 25th October 2008, 06:06 PM   #1
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Smile Line Out for highgain BoSoZ
Gentlemen....
For the last couple of month's, i have been fiddling around, with a setup of my Fostexfe207e-halfchang fullranger spk. + an 12" plateamp powered servosub.
This is a setup, i really appreciate, as it give's me, what i found was missing on the fullranger... But i think it could be even better as it is now !
The servosub, is feeded on it's highlevel input, e.g at my F4's spk. terminals. Reason for that, is that my volcontrol on my BoSoZ is placed at the output. The servosub cannot accept signal at that range on it's normal linein.
What i would like to have, is a line-out on my BoSoZ, giving max 3vac out. My BoSoZ has only balanced output's, through XLR's. I am thinking about drilling holes for two rca's for lineout. - Reason i would like this, is that i would like to attach a passive filter at my F4's input, filtering out the bass to my fullranger's.
I have been reading about inline attenuator's and how they work, how they affect the impedance and so, but was wondering if there is a betterway of doing it. Also i donno if a L/H or whatever pad attached in parrellel on my BoSoZ output, would affect the impedance much or if it would affect the output i am using for driving my F4's ?
Any hint ?
Jesper.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 25th October 2008, 09:07 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: Line Out for highgain BoSoZ
Originally posted by lykkedk
Gentlemen....
Any hint ?
Jesper.
what you really need - line out , before pot ...... or what ?
crazy danske
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th October 2008, 09:39 PM   #3
Magura is offline Magura  Denmark
Magura's Avatar
Default Re: Re: Line Out for highgain BoSoZ
crazy danske
What Jesper is trying to say, is that he needs a line out before the pot, and he wants you to say it
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 25th October 2008, 09:52 PM   #4
lykkedk's Avatar
Your'e crazy both of you ...
I need a lineout, but not with the voltageswing, giving at the output at my BoSoZ, where my volcontrol is !
Jesper.
Old 26th October 2008, 12:16 AM   #5
dave_gerecke is offline dave_gerecke  United States
Perhaps you could add in the unbalanced output after the volume control, but put in an attenuator circuit to feed from the output of the volume control to the output for the sub!? Just my silly thoughts.
Peace,
Dave
Old 26th October 2008, 08:48 AM   #6
lykkedk's Avatar
Yes, i was also thinking about using +out / gnd, for lowering the voltageswing, but it's still not enough... With a 1vac input, the unbalanced out gives ~8-10vac.
I have found this somewhere else, in this forum, and maybe it could be usefull. I still donno if it will affect the normal output much. - This connection, has to be done in parrelel to my normal output XLR.
Jesper.
Old 26th October 2008, 09:51 AM   #7
Magura's Avatar
Build another BOSOZ, and try if you can, to just leave the gain setting at 12
Magura
Old 26th October 2008, 10:01 AM   #8
lykkedk's Avatar
Actually, this is still too much output...
Jesper.
Old 26th October 2008, 10:18 AM   #9
Magura's Avatar
Jesper.
Well, as the master of gain, you sure know how to lower it to the level needed, no?
Magura
Old 26th October 2008, 10:35 AM   #10
Zen Mod's Avatar
Magura
nope ;
lykkkkk is good just for gains above 100 ;
(or it was 1000 ? )
- I'm still clueless what he wants
Line Out for highgain BoSoZHide this!Advertise here!
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 02:57 AM
Akai GX 265D line voltage on line outs? ShorBird Solid State 11 26th January 2009 11:44 PM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 12:55 AM
Grounding thev Balanced line stage(BoSoz) Amj_ciron Pass Labs 21 16th July 2002 12:22 PM
Copyright ©1999-2017 diyAudio
