Hi all,
My SL-10 works perfectly in all its functions: line, monitor, MM phono input ... except the MC phono input. It's some time using the MC phono, the right channel produces a strong buzz-uhmmm, as if the turntable's ground is not connected, but only on right channel!. I'm not an expert in repairs but since the trouble is only at one section, perhaps with your help I might be able to identify the cause. The noise is the same in all three positions of impedance. Here is an inside attachment... |
#2 |
...and schematics.
Thaks so much for help. |
#3 |
Any idea?
#4 |
This should be really easy to fix. First of all inspect and resolder all solder joints in the MC section - input jacks, connections to pcb, pcb itself. It may even be an almost broken wire. It is less likely that the electrolytics are to blame but it certainly wouldn't hurt to replace them - they are all way past their prime. The 4.7uF caps will deserve really good quality replacements - BG-N will be very suitable.
#5 |
Preamp has been recapped recently with Elna Silmic II. Maybe one of them has blown...
I'll check them and all solder points. Thanks for help. |
#6 | |
blown caps - not likely ; cold solder joints or defective transistor in input
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
| DC Offset on the input of a Threshold SL10 | hifi-hospital | Solid State | 10 | 25th February 2007 08:26 AM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| convert Quad44 radio input to CD input | jives11 | Solid State | 11 | 5th March 2005 02:33 PM |
| Page generated in 0.07638 seconds (84.33% PHP - 15.67% MySQL) with 11 queries |
