Hello DIY friends.
Who can give me an advice. Which preamplifier should I prefer or which one sounds better in combination with a Aleph 2. The balanced line stage or the Aleph P 1.7? I would like to build one of both and need a small decision help. |
#2 |
They sound about the same. BZLS is alot easier, but you get some losses on undriven side when converting unbalanced to balanced (the Aleph doesn't care though).
I say go for the BZLS! (This is what most people do).
Mads K |
#3 |
hello Mads,
thanks for your advice. The Aleph P preamplifier does not seem to be very popular among the DIY´lers, in the comparison to the BZLS . From where do you know that both pre amps sound almost similarly , have you both already heard? Thank you Martin |
#4 |
i'm building a aleph p 1.7. i've already got some dale resistors !!. and some used terroid's . But building is in progress iám waiting for the matched MOSFET to arrive
gr jaac |
#6 |
Mad K,
Do you have any experience with the BZLS and Aleph using balanced connections ? Does it affect the sound much with those different output levels ? Nick |
#7 | |
Mads K |
#8 | |
Yes, I use BZLS and A30 balanced. I have both balanced and unbalanced sources. It doesn't affect the sound per see, it affects the CMRR. This figure I wouldn't loose any sleep over
Mads K |
#9 |
So stop tweaking and start listening ????
Grtz Nick |
#10 |
Build the BZLS! it's simply wonderful
and it only gets better when you use Balanced equipment. a very flexible treat from Mr. Pass. and if i can do it, anyone can! m. |
| Page generated in 0.11099 seconds (76.07% PHP - 23.93% MySQL) with 10 queries |
