Old 15th October 2008, 08:08 PM   #1
Default A newbie question
I am owner of two transformers.
2xTR400
250VA double isolation.
Dimensions: d=126mm h=65mm
Primary: 2x115 Vac
Sec. main: 2 x 0-40 Vac
Sec. aux1: 13-0-13 Vac
Weight: 2.9kg
Transformer is Audio Graded, fully potted, and with electrostatic screen between primary and secondary windings.
So my question is, I want to make a clone of firstwatt F3 amplifier, can I use these transformers or the vac of 2*40 is too much for these amplifiers?
Thank you
Old 15th October 2008, 10:31 PM   #2
The one and only
Nelson Pass's Avatar
A 40V secondary will give you about 55 volts, and since the F3 regulates
that down, you will have a nice range of voltage adjustment, and you can
use one secondary per channel. It will probably run a little hot, but you also
have the option of dropping the voltages by putting an inductor in series with
the windings, which will also improve the power factor of the supply.
Old 16th October 2008, 02:21 PM   #3
And the last question!!
Which is the best value of dropping the voltages?
Thank you
Old 16th October 2008, 05:30 PM   #4
hifimaker's Avatar
Consider trying Duncan's freeware PSU Designer II emulation software. It's a superb tool to design and emulate power supplies with almost any combination of chokes, resistors, and caps.
A lot of DIYer's use it on this site.
http://www.duncanamps.com/psud2/index.html
-David
Old 20th October 2008, 05:27 PM   #5
Default Thanks for the responce
My quetion is not for the way to do it, but for the best voltage for the amplifier, for example the circuit says 18V.
Thank you
(Newbie) CSS Question bibster Tubes / Valves 8 24th January 2007 10:22 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
newbie question kambrian Multi-Way 5 28th December 2003 10:16 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Page generated in 0.07683 seconds (76.97% PHP - 23.03% MySQL) with 10 queries
