PP or Balanced? - Page 2 - diyAudio
Old 11th October 2008, 06:00 PM   #11
The one and only
Nelson Pass's Avatar
Probably a typo. Happens to the best.
Old 11th October 2008, 08:33 PM   #12
Blues is offline Blues  United States
Blues's Avatar
Originally posted by Tyimo
Hi Lineup!
You are right!
Here is the questionable circuit:
That's a Balanced Single-Ended, sez I...
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 12th October 2008, 10:32 AM   #13
Tyimo is offline Tyimo  Hungary
I think too.
But, than what is that circuit? PP or Balanced......?
Tyimo
Old 12th October 2008, 10:02 PM   #14
The one and only
Balanced single-ended is an oxymoron, but it describes two single-
ended Class A circuits run in balanced mode.
I don't think it has IEEE status as a circuit description.
Since the inductive loads are coupled to each other, I would probably
call that balanced push-pull.
If the Mosfets each had a separate inductor not coupled to the
other then it would be balanced single-ended.
Old 13th October 2008, 05:56 AM   #15
Thank You Master!
Since the inductive loads are coupled to each other, I would probably call that balanced push-pull.
Yes, then in that circuit the bias for each device is set to
1/2 the peak output current. (?)
Tyimo
Balanced Zen v. Borbely SE Balanced Pete Fleming Pass Labs 7 22nd February 2005 03:59 PM
Balanced Zen v5 + balanced Zen line stage Adrie Pass Labs 0 30th May 2004 06:27 PM
Balanced Zen 5? Johan_Ch Pass Labs 1 10th August 2003 07:56 AM
Balanced DC servo for balanced stage ? CheffDeGaar Solid State 8 9th July 2003 03:39 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 07:18 AM
Copyright ©1999-2017 diyAudio
