Hi everybody. I have a question. The heat sink I can find here is 150 (h) x 100 (w) x 25mm (d). I intend to mount the mosfet onto the heat sink. Please see attached images. Will this be enough? These heat sink are from China and o specs on them. Please help.
#2 |
how much heat do you need to dissipate?
What temperature is acceptable at the FET case?
regards Andrew T. |
#3 |
Thanks for reply. I would like to have the case at 55c. This is A5 mono.
#4 |
Maybe you can try to mount a resistor and plot the temp rise at various point with some thermometers.
#5 |
Think 1.5C/W for a single of those 150mm/6" heatsinks.
So 2 rows of 4 heatsinks should be able to handle the 150W. It's not such a bad idea to use those sleek heatsinks, if you don't mind the 40cm/16" depth of the amp.
Looks like Sponge Bob has killed another thread. |
#6 |
I haven't got the heat sink yet. They are expensive and I can't afford to experiment with trial and error. These are the medium size heat sink, the bigger size ones are way too large and the smaller ones is a bit too thin.
#7 |
Then estimate the C/W number with a thermal resistance calculator.
#8 |
Thanks, I do not mind the 400mm depth at all. So, these heat sink should be able to handle the heat. Thanks for the help. I will go ahead with the plan.
#9 | |
NO! What people have told you, is based on guessing. To you it should translate into something like: "Those heatsinks are worth checking out a bit closer, and do some calculations." As Jaccolina stated above, there are online dissipation calculators around, and if sucha a calculation tells you that the heatsink is big enough, well, then it's a bit closer to a green light. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#10 | |
Dissipation calculators? Please pardon my stupidity, I do not know how to use these calculators. The maths involved is too complex. |
| Heat sink insulator | ECM | Car Audio | 25 | 6th September 2006 04:07 AM |
| Aleph P1.7 heat sink? | sugano | Pass Labs | 1 | 11th July 2006 02:56 PM |
| heat sink for UCD700? | pburke | Class D | 68 | 7th July 2006 04:40 AM |
| Heat sink schematics | Llafriel | Pass Labs | 10 | 18th June 2004 07:05 AM |
| How much heat sink is necessary? | rosss | Pass Labs | 11 | 23rd February 2003 05:23 AM |
| Page generated in 0.09395 seconds (77.14% PHP - 22.86% MySQL) with 11 queries |
