small signal device matching procedure (as in LSK170)
Old 9th October 2008, 03:46 PM   #11
FUCHSAUDIO is offline FUCHSAUDIO  United States
FUCHSAUDIO's Avatar
Send a message via AIM to FUCHSAUDIO Send a message via Yahoo to FUCHSAUDIO
Default I've used this successfully.....
http://www.geofex.com/Article_Folder...h/fetmatch.gif
This is an active FET matching fixture. I've made a PCB layout in expresspcb for it, and it works well. If anyone wants it, send me an e-mail for the file.
Old 9th October 2008, 04:17 PM   #12
R.I.P.
geofex not found
regards Andrew T.
Old 9th October 2008, 04:19 PM   #13
R.I.P.
absolute accuracy is not too important, unless you are sharing data with others.
Repeatability is important.
Today's results should compare to yesterday's and last year's and next year's.
regards Andrew T.
Old 10th October 2008, 02:30 AM   #14
anatech is offline anatech  Canada
anatech's Avatar
Hi Andrew,
You need to control the device temperature in that case.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 10th October 2008, 04:39 AM   #15
flg is offline flg  United States
flg's Avatar
Matching Idss amongst bottom and top transistors should assure a median voltage at the output, I guess it's cap coupled though anyway But, this also gives max + and - voltage swing at the outpuit It also suggests gain to be very similar between the 2 devices.
I've read were because both transistors are not operting in the same configuration, that matching dosent matter??? It dose not take much mismatch to cauase the output to go to one rail. Therby having 0 volt swing to one rail
Output queicent offset voltage may not be best at midpoint of the supplies though. It is good not to draw to much gate current or saturate the device to much
Old 10th October 2008, 05:57 AM   #16
steenoe is offline steenoe  Denmark
steenoe's Avatar
Default Re: I've used this successfully.....
Fuchs;
Looks interesting. Is that rig temperature stable, it looks like it? The usual way with a power-resistor is very edgy, temp-wise.
Please turn on your email. (or mail me)
Cool looking amps on your homepage. Just spotted that my hero Joe Bonamassa has one
BTW, nice thread.
Old 10th October 2008, 02:32 PM   #17
FUCHSAUDIO's Avatar
Default Yes it is.
I buy a bag of 100 or 200 Fets for production, and group them in bins by the test numbers. Makes life so much easier. I believe the rig can be considered temperature stable, as the FET is not under any stress that might heat it up or make it vary it's operating point.
I'll check my settings to make sure I'm open for getting e-mails.
Old 10th October 2008, 07:33 PM   #18
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
[url]This is an active FET matching fixture. I've made a PCB layout in expresspcb for it, and it works well. If anyone wants it, send me an e-mail for the file.
Welcome Andy!
Old 10th October 2008, 07:45 PM   #19
FUCHSAUDIO's Avatar
Default Back at cha !
Howdy Nelson. Thanks for the welcome !
FET Matcher artwork is attached. www.expresspcb.com
Old 10th October 2008, 08:05 PM   #20
anatech's Avatar
Hi FUCHSAUDIO,
You need to control your ambient temperature. For me in the basement of my house, that's a problem. For a business office, might not be. I still had to watch the vent air in my business.
I just wanted to point out that the FET may measure differently if the ambient drifts. It's the same with BJTs.
I take this one step further and thermally tie transistors together in a diff pair jig (posted in a couple places here). As long as the temperature is the same on each part, you can see how they balance in the testing jig. It's just a common emitter/source through a current source with collector/drain and base/gate sensing resistors. It works very well for matching parts closely. It does take time to allow the parts to reach thermal equilibrium.
-Chris
small signal device matching procedure (as in LSK170)Hide this!Advertise here!
Output transformer matching to active device driving it macrohenry Solid State 3 17th August 2007 06:51 AM
M3 Semiconductor Analyzer - Cool kit for device matching DCPreamp Solid State 6 17th December 2006 06:01 PM
Gain Matching Output device ???'s Zero Cool Everything Else 6 10th December 2006 04:56 PM
Question on device matching BrianGT Pass Labs 9 4th April 2002 03:31 AM
Device Matching Automation - A better way alaskanaudio Solid State 5 29th November 2001 10:20 PM
