PassLabs Aleph 4.0
PassLabs Aleph 4.0
Old 15th October 2008, 10:09 PM   #11
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Default Hi!
Originally posted by jacco vermeulen
Tomas,
ditto here, me old and blind.
(bigger pics of the girlfriends too, please)
For Me 2!!
Regards zeoN_Rider
Old 16th October 2008, 05:00 AM   #12
lineup is offline lineup  Sweden
lineup's Avatar
You can download Aleph 4 schematics from Russia.
http://schematic.narod.ru/a_index.htm
lineup
Old 16th October 2008, 06:07 AM   #13
stoN_Cold's Avatar
Default Hi!
Thanks LineUp, but this is Gen. Pass Labs Service
manual!
I ment schematic of t_majerovic!
Regards zeoN_Rider
Old 16th October 2008, 06:26 AM   #14
lineup's Avatar
If I wanted to build this amplifier and had 2 versions to chose from: N. Pass or T. Majerovic,
it would be a nightmare to make up my mind.
They could both work very well.
One thing extra in Majerovic's version is relay operated protection circuit.
Otherwise I do not think he has changed much form the original.
I would not do this myself.
Because Nelson test his amplifiers well before offer them to people.
He does not only listen to the sound. He makes some nice data curves, too.
In order to be sure he is not imagine and to trim for best electrical performance.
lineup
Old 16th October 2008, 11:45 AM   #15
stoN_Cold's Avatar
Default Hi LUP!
Relay operated protection circuit.
That what I, tallking about!
Regards zeoN_Rider
Old 16th October 2008, 02:50 PM   #16
t_majerovic is offline t_majerovic  Slovakia
t_majerovic's Avatar
Cool Comment
Audio part is Aleph 4.0 without any modification except replacement IRF244 by IRFP240 and my own PCB design. Power supply (with soft start on/off sequencer) and speaker protection circuit are my own design. I prepare schematics in better quality and attach here.
Protection circuit must be part of each kind audio power amplifier without output capacitor. I follow this rule and it save my speakers many times. I also prefer delayed switch on amplifier output.
Old 17th October 2008, 01:27 PM   #17
Default Schematics 1
Aleph 4.0
Protection circuit (tested on simulator only!)
Old 17th October 2008, 01:43 PM   #18
Default PCB Aleph 4.0
PCB wit Aleph 4.0 (except power mosfets) + protection circuit
Old 17th October 2008, 02:12 PM   #19
stoN_Cold's Avatar
Default Hi t_majerovic !
Nice work, what about "Values"of parts?
Regards zeoN_Rider
Old 17th October 2008, 06:20 PM   #20
I didn't publish values because protection circuit is tested only in TINA simulator and not on real/physical circuit. So I can't 100% promise that this schematics will work without any modification. So, anyway. If you are interested here is exported schematics from TINA simulator.
Few notes to components values/types are here:
switching transistor controlling relay is replaced by TIP117 TO220 in physical circuit
R13 (connected to emitter of TIP42 ) presents relay internal resistance - FINDER 40.61S, 24V/900R,One pole
zener diodes Z2 & Z3 1N3022 is replaced by BZX85/C15 in physical circuit
zener diode (connected to collector to TIP42) is replaced by BZX85/C24 in physical circuit
bidirectional dual color LED diode is BL-BHG234
switch SW-SPST1 in simulation circuit is replaced by LTV826/DIP8 in physical circuit
C1 47uF in simulation circuit is replaced by two 100uF capacitors C7 & C8 in physical circuit
Expected issues:
circuit sensitivity (too big)
insufficient current over dual color LED
PassLabs Aleph 4.0Hide this!Advertise here!
FQA12P20 for use with Passlabs F5 etc dhole Swap Meet 4 13th March 2009 01:23 PM
www.passlabs.com down? Mickey Pass Labs 2 7th February 2008 12:02 PM
Passlabs D1 with DC servo ? shf1107 Pass Labs 9 22nd December 2007 04:46 PM
Passlabs Becomes Complex A'af Pass Labs 17 16th October 2003 03:22 PM
Passlabs Aleph 5 project????? Chamberman Pass Labs 3 14th June 2001 08:53 PM
