The Amazing Fet Circlotron by Mike Rothacher
Old 11th December 2011, 05:03 PM   #191
Tubenstein is offline Tubenstein
Hello!
My friend has sent me this circuit since I used to interest in building a hybrid circlotron amplifier, but not now.
Refer to the circuit builder claimed that "the CIRC1 will develop about 60 watts with 12 volt supplies as long as the power supply can provide the required 13 amps current, as technically it is biased in Class AB but with a high Class A standing current. It is possible to adjust the bias on the CIRC1 to a lower level allowing a much more efficient output stage."
I do a search and the IXTH20N50D is a 500V 20A, what is the highest power to get the most from this device by not causing any harm to its "linearity"?
Old 11th December 2011, 09:54 PM   #192
steveu is offline steveu  United States
An important point about this topology is that you need two floating supplies for each power stage, plus another supply for the driver(s), so for stereo you would need five independant power supplies, ie only one of which can be connected to ground.
Old 20th June 2012, 08:05 PM   #193
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default Andrea Ciuffoli's Circlotron
in this case Andrea Ciuffoli's circlotron (author from the famous and good known diy projects "Power Follower" and "Cool Follower") could be also of interest - go to
Thorens TEM 3200 clone
Old 10th September 2013, 10:41 AM   #194
JohanH is offline JohanH  Netherlands
I'm biting the bullet on this one and started gathering parts.
In a conversation elsewhere someone mentioned that power dissipation in R11/12 can reach peak values of 1 watt.
As I intend to build this with Vishay bulk foil resistors with a nominal power dissipation of 0,4 watts, I'm wondering I should be worried...
Thanks in advance for your input.
Johan
Old 10th September 2013, 12:21 PM   #195
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
If it's important to use those resistors, you could use two to make up the value, unless you plan on really beating the amp to death, then use three.
Visit AudioMaker.Tech
Old 10th September 2013, 12:47 PM   #196
Ok,
thanks Michael.
Are there other things to consider?
Johan
Old 10th September 2013, 12:55 PM   #197
AudioMaker.Tech
That's the only erratum I'm aware of right now.
Old 12th September 2013, 10:41 AM   #198
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
I would like to see a PCB for this in the DIYAUDIO store.
Any chance of that happening?
EDIT: Actually, I would like to see at least 3 different circlotron amps in the diyaudio store.
1)This one
2) A power buffer (source follower) to attach to the output of the balanced BA3
3) And something entirely different from Nelsons crazy brain
Old 4th January 2014, 11:19 AM   #199
Resistor values and reference of R13,R14 and R15,R16 are reversed in BOM vs schematic. Which is correct?
Thanks in advance,
Johan
Old 4th January 2014, 01:58 PM   #200
AudioMaker.Tech
The schematic is the correct one.
The Amazing Fet Circlotron by Mike RothacherHide this!Advertise here!
Mike's Proposed MTM Mike C Multi-Way 34 5th December 2007 09:33 PM
Inexpensive mike? audiobomber Multi-Way 10 27th February 2007 11:45 AM
Mike's Project - MTM? Mike C Multi-Way 1 9th January 2007 10:09 AM
Circlotron djk Pass Labs 13 20th August 2006 03:19 AM
Measurement mike lndm Everything Else 6 29th March 2006 08:25 PM
