The Amazing Fet Circlotron by Mike Rothacher
Old 29th April 2011, 10:10 AM   #171
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
Originally Posted by cnpope View Post
Gyuri: Well I suppose I did more or less copy the construction style I used for my OTL based on Tim Mellow's design:
Chris
Well, Chris, you're a true artist of DIY.
So much that I decided, I make an amplifier such as that you do.
(Maybe this is not just me at this place would have had to say.
Here now because I thought the OTL.)
However, if someone put his foot to Papaland, not an easy to release.
I present to you one of my Amplifiers:
http://www.diyaudio.com/forums/pass-...-quad-zv9.html
I also recommend that you build this.
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 27th August 2011, 09:30 PM   #172
coolnose is offline coolnose  Europe
coolnose's Avatar
Default Part choice..
Hi folks,
I read the article and the thread related to the circlotron and will give the build a try.
Is there any reason not to use wirewound resistors for the power resistors ?
Are the values of 100 Ohm and 0.47 Ohm (3 Watt each) critical for the design ? I am asking because I have some 0.56 and 0.82 in my drawer.
Anty reason not to go higher on the supply rails ? I would have some 24V secondaries on the shelf as well...
Max
Old 27th August 2011, 10:07 PM   #173
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
You'd be pressing your luck with 32 volt rails. Get 100 Ohm resistors. Wirewound is fine.
Old 27th August 2011, 11:48 PM   #174
AudioMaker.Tech
The .56 is okay.
Old 24th October 2011, 07:25 PM   #175
dnewman is offline dnewman  United States
Default Circolotron build
A vanilla Amazing FET Circolotron build. JFETs are 2SJS109BLs and the MOSFETS are matched FQA19N20C pairs. The resistor pairs are also matched. I opted to inset the top panels inside of the boxes rather than secure them to the tops of the boxes. (The panels are one half inch narrower in width and height.) So far they sound nice. After a couple of weeks, I'll measure them.
Click the image to open in full size.Click the image to open in full size.
Michael, thanks much for all the hard work in putting this project together!
Dan
Old 25th October 2011, 11:45 AM   #176
AudioMaker.Tech
Nice build, Dan. The potted transformers look good.
Visit AudioMaker.Tech
Old 26th October 2011, 03:26 PM   #177
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Default The All JFET Circlotron
Hi Michael, Is the JFET Circlotron build/article getting any closer. I bought some SIC JFETs last year and have been searching for something to build with them.
Currently listening to F4 or F6/wSS outputs
Old 26th October 2011, 09:13 PM   #178
AudioMaker.Tech
Even if I finish it in November, you have to figure it probably wouldn't be published until after the new year.
Having said that, it's really not going to be much different from the original (or at least that's what I think right now).
Old 27th October 2011, 08:13 PM   #179
qusp is offline qusp  Australia
qusp's Avatar
thats what i thought initially too, but i'm thinking its just a regular transformer in a can, the outside looks metal.
for those impatient Michael has documented the R100 circ on his DIYA blog using these boards and it is indeed pretty much identical
Old 27th October 2011, 08:24 PM   #180
Correct -- it's just a transformer in a can. A very heavy can. It's a 300 VA transformer from Antek with one of their well constructed cans. My only grip with the can was that it was supposedly powder coated. While that may be the case, it wasn't a very durable coating. While I had had it for about three weeks (and hence the coat was at least three weeks dried/cured/whatever), it would scratch just by my looking at it. So, I had to refinish both cans. However, I'd buy them again should I need/want them as they are very well built. And, I'm quite satisfied with the Antek transformers I've used.
Dan
The Amazing Fet Circlotron by Mike RothacherHide this!Advertise here!
Mike's Proposed MTM Mike C Multi-Way 34 5th December 2007 09:33 PM
Inexpensive mike? audiobomber Multi-Way 10 27th February 2007 11:45 AM
Mike's Project - MTM? Mike C Multi-Way 1 9th January 2007 10:09 AM
Circlotron djk Pass Labs 13 20th August 2006 03:19 AM
Measurement mike lndm Everything Else 6 29th March 2006 08:25 PM
