The Amazing Fet Circlotron by Mike Rothacher
Old 7th November 2008, 10:05 PM   #91
stoolpigeon is offline stoolpigeon  Australia
stoolpigeon's Avatar
Hi Mike,
I would appreciate that.
I have some efficient speakers so low power is fine. I am also used to an original Zen which I think has much higher distortion anyway.
thanks, sp
Old 8th November 2008, 10:51 PM   #92
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
sp:
With 12V rails I saw .03% THD at one Watt hitting 1% at around seven Watts. That's keeping the 1.2A bias and no circuit changes.
I leave it for you to decide if that's okay.
Old 9th November 2008, 01:12 AM   #93
Thanks Mike!
I will proceed.
sp
Old 27th April 2009, 10:15 AM   #94
gaborbela is offline gaborbela  Canada
Hello
It is possible to use 2SK1529 power mosfet instead IRFP240.
EUVL U are familiar with these Toshiba mosfet would you please let me know .
If I have to change some resistor values please let me know .
Thank you very much .
Greets .
Old 27th April 2009, 02:42 PM   #95
bear is offline bear
expert in tautology
bear's Avatar
Thought I might mention that if the original photo posted is not fan cooled, then the heatsink is apparently rotated 90 degrees from its proper position for natural convection operation...
Also, the bottom of a heatsink used for natural convection needs to have an unimpeded source of air - usually a volume equal or greater than the open area of the heatsink (on the bottom) in order to not create a resistance that reduces the convection...
and an equally free route out the top.
For most class AB amps it doesn't matter usually because the heat load is usually lower and if highish usually transitory. Class A is constant heat (of course).
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 27th April 2009, 03:26 PM   #96
el`Ol is offline el`Ol  Germany
May I post a simplified schematic of the patented Thorens circlotron amp, which is the official reference of a German hifi magazine (more or less confirmed by 6moons)?
Old 27th April 2009, 06:59 PM   #97
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
You will want to ask Mike.
Old 27th April 2009, 08:15 PM   #98
EUVL is offline EUVL  Europe
You can use 2SK1529Y but you might find that the trimpot to bias the Vgs of the MOSFET has to be lower in value. Perhaps you trim it first and then consider replacing it with a fixed resistor afterwards. 2SK1529 has about 1.5V less Vgs than IRF at the same current.
As to the Thorens schematics, you'll find out more about his "invention" than this HiFi magazine schematics. He did not invent the circlotron circuit he used, just the bias stabilisation, which is essentially a common-mode servo plus a differential servo.
Amazing what people can patent these days, including method to identify certain genes of a pig !!!
Patrick
Old 28th April 2009, 08:31 AM   #99
Samuel Jayaraj is online now Samuel Jayaraj  India
Patrick (EUVL) perhaps, you are the only one other than Nelson who can comment about the sound of the Circlotron vs F5 at the time, having built both; would you like to go ahead.
Thanks.
Sam
Old 28th April 2009, 01:04 PM   #100
AudioMaker.Tech
I've listened to the F5 very briefly, but not side-by-side with the Circlotron. I suspect they're very similar. One day I'll build an F5 and make a real comparison, but alas, I haven't been able to do much hobby-wise lately.
The Amazing Fet Circlotron by Mike RothacherHide this!Advertise here!
Mike's Proposed MTM Mike C Multi-Way 34 5th December 2007 09:33 PM
Inexpensive mike? audiobomber Multi-Way 10 27th February 2007 11:45 AM
Mike's Project - MTM? Mike C Multi-Way 1 9th January 2007 10:09 AM
Circlotron djk Pass Labs 13 20th August 2006 03:19 AM
Measurement mike lndm Everything Else 6 29th March 2006 08:25 PM
