Help Needed on the Aleph 1.2 Mechanical Layout
Old 28th March 2003, 05:55 PM   #1
jewilson is offline jewilson  United States
Send a message via AIM to jewilson
Question Help Needed on the Aleph 1.2 Mechanical Layout
I need help to locate a picture of the inside layout of the Aleph 1.2 or even the 2 amps. I'm a little confused that the power MOSFET's are located on all four sides of the amp. Therefore, I very interested to know what are the wiring and layout pits falls before I began my project.
This method obviously is different that other amps where the transistors or located on the right and left side. Maybe some one
can help me with my out with my confusion and a Picture. I have purchased surplus Passlabs heart sinks, so I want them to be close to the original mechanical layout.
Jim
Jim W.
Old 29th March 2003, 03:52 PM   #2
Question Perhaps Nelson Pass Would Share a image of the guts of his ALEPH 1.2 amp
Dear Mr. Pass,
Perhaps you have a JPEG image of the in side of your Aleph 1.2
you could share with us. We are using some surplus heat sinks
of your and would like to follow you original internal layout and
mechanical implementation.
Thanks for your Help
Jw
Jim W.
Old 29th March 2003, 05:13 PM   #3
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Help Needed on the Aleph 1.2 Mechanical Layout Send a message via AIM to Peter Daniel
Here's pic of Aleph 3: http://www.diyaudio.com/forums/showt...aleph+tweakers
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 29th March 2003, 05:18 PM   #4
And here are some noce pics of Aleph 0. Those are not exactly what you are looking for, nevetherless can be a good source of inspiration
http://www.diyaudio.com/forums/showt...s&pagenumber=2
www.audiosector.com
Old 29th March 2003, 06:17 PM   #5
Cool That helps But
http://www.diyaudio.com/forums/showt...p;pagenumber=2
Thanks Peter,
Does the Aleph 1.2 have the transformer located underneath the amp in it's only box. One of my concerns is the wiring distribution mess this could create. After closer examination, it looks like Nelson has a mother board which carries power and signals and hold the input circuitry. This seems to be the way to go if replicating the amp internal design. However, it seems like the square amplifier with transistor on all sides is more of a hindrance to the layout. Of course, the stray capacitance to outputs would seem to increase with this implementation. Any help is greatly appreciated.
Jim
Jim W.
Old 29th March 2003, 07:03 PM   #6
It all depends on available heatsinks. If they are big enough, using heatsinks on both sides only is much easier, considering layout and construction, although may not be as much appealing visually You might try Pass Gallery as well for some ideas.
Personally, I like Aleph 0 chassiss very much and consider it a classic. The later Alephs show more of a convenience reasons applied to construction. Of course the later designes provided more heatsink area
www.audiosector.com
Old 29th March 2003, 07:40 PM   #7
Default Layout issues
We are using the same heat sinks that Nelson Pass used. A friend found these in a surplus metal shop in Calf. However, I did not know their was a bottom section for the transformer and extra hardware till you listed the link. So are the larger (1.2 and 2] amps built with the same concept, the transformer located underneath the main chassis? That would make sense. I like the way you laid out your amp out it make a lot of sense. Also, as you noted there are some very good ideas on the site, but I'm locked in to the original design concept because 3 of us are building them.
Now I'm wondering if I will need to layout board for power and signal distribution to make the layout clean. Maybe
I can unwrap some flat inductors to carry the power and out put of the main input board to make it simple.
Jim
Jim W.
Old 2nd April 2003, 11:10 PM   #8
LBHajdu is offline LBHajdu  United States
Here you go :
Old 2nd April 2003, 11:35 PM   #9
Default ALEPH LAYOUT
Thanks LBHajdu,
Peter Daniel has already sent me a link to this. Looks like the Aleph 1.2 is just and over grown Aleph 0 amp.
Peter, I know you've have built a version of the Aleph 2 using a more conventional layout method. Do you see any problems using the MOSFET on all side of the amp be side the length of signal runs. The Aleph sure is a different approach, it's also interesting that Nelson newer amps have gone back to the traditional layout method.
Maybe, not sure, it would be worth the effort to layout a PCB for the power supply, and signal and power runs, any ideas?
JW
Jim W.
Help Needed on the Aleph 1.2 Mechanical LayoutHide this!Advertise here!
Amplifier Layout - Help & advice needed andrew_whitham Tubes / Valves 5 8th May 2007 08:49 PM
Looking for Aleph 2 layout punchpeanut Pass Labs 10 6th July 2004 04:36 PM
Transistor pin-layout needed Jennice Parts 2 1st November 2003 09:19 AM
Help Needed with layout GazzaFloyd Parts 0 5th July 2003 08:22 AM
Copyright ©1999-2017 diyAudio
