Old 3rd December 2001, 03:52 PM   #11
jduncan is offline jduncan  United States
Send a message via AIM to jduncan
Im half asleep but why will you get a peak of 75 volts?
at the primaries you will have 37.5Vrms or about 53Vpeak...after rectification you will just have a rectified wave with a 53V peak....you wont get near 75V...
Old 3rd December 2001, 06:20 PM   #12
The one and only
Nelson Pass's Avatar
Given the probable losses you won't even get 50 volts.
Old 3rd December 2001, 06:20 PM   #13
So when I wire two power sources with the same voltage, in this case the dual primarys, in series I end up with the same voltage I would obtain from wiring just one of the primarys to the same circuit. Is that the general idea? I didn't know if that was the case or not and took the guess that you could add voltages. Just curious how does a wave with peak 53 volts create a relatively similar consistent voltage? Oh, well thanks for the correction.
Rob
Old 3rd December 2001, 07:07 PM   #14
The consistent voltage is created by the capacitors....
they will charge very close to the peak of the wave reaching them
aleph capacitors available MikeZ Pass Labs 0 15th September 2006 02:04 AM
Aleph-x capacitors anders.a Pass Labs 1 9th April 2005 02:55 PM
Capacitors at Aleph 3 Odysei Pass Labs 1 27th July 2004 03:29 AM
Capacitors for the Aleph 2 Hydesg Pass Labs 2 23rd February 2003 03:31 PM
Aleph P Capacitors USI Pass Labs 1 23rd January 2002 10:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
