Banned
I would simply like to know why passive pots lack dynamics and bass?
This has been my own experience with them and I'd like to know what kind of distortion could cause such effects? |
#2 |
The eternal question, torturing mankind since the dawn of time
Impedance matching, dear professor, impedance matching !
#3 |
Banned
ok well could someone explain the details of this to me?
what is impedance mismatch and how does it make the sound lacking in dynamics? |
#4 | |
Please consider getting "The Art of Linear Electronics" by John Linsley Hood. It covers all the essentials about audio electronics, like filters, impedances, circuit theory, etc. The book is now in reprint from Audioxpress: http://www.audioxpress.com/bksprods/BKSELEDES.htm Also consider reading Nelson's prior articles on the ZEN line of preamps and amps. They are available on www.passdiy.com. Both of these resources are a gold mine for learning! -David |
#6 | |
well impedance mismatching is the theory that stands behind the maximum transferred power. Now the theory says that a real generator with its internal resistance connected to a load transfers the maximum power to the load when the load has the same impedance of the internal resistance of the generator. The power figure is, if i don't recall wrong, an upside down parabolic behavior (the maximum is Pgen/2). As you can understand by varying the load connected to generator the ability of the system to transfer power varies accordingly. How do we summarize this? A passive attenuator's system obviously varies the impedance seen by the stage behind it as the volume position varies. This leads to the problem of different adaptive conditions at different volume level positions and not all them will be the ideal one, of course. As the dynamic might be defined as the ability of an amplifier to output power", you easily understand how this, of course, affects the above parameter. Stated this, i like them both : active and passive volume control system. I would personally try to make them both and see what i like the most. Hope this helps.
Stefano |
#7 | |
The one and only
is a common perception that this is so. Having the wiper see a high impedance load seems to improve it.
#8 |
Banned
What does reducing the current of the signal source do to the sound?
I have heard that this is what causes the lack of bass drive and dynamics, is this a myth? |
#9 |
The one and only
Probably. It's a conclusion lacking context. I can probably come up
with counter examples pretty easily. |
| Passive Attenuator kits?? | Zero Cool | Solid State | 2 | 21st February 2006 11:41 PM |
| $2000 passive attenuator | MichaelJHuman | Everything Else | 21 | 30th August 2005 09:45 PM |
| DIY Audio source passive attenuator | obx | Parts | 3 | 28th January 2005 09:39 AM |
| Passive I/V: I/V resistor as attenuator | Steve Eddy | Digital Source | 16 | 20th April 2004 07:47 AM |
| passive attenuator design | lbenoit | Solid State | 3 | 1st March 2004 10:51 AM |
| Page generated in 0.09872 seconds (77.82% PHP - 22.18% MySQL) with 10 queries |
