I was leafing through one of my older notebooks today and
came across something you may like.
A number of you have asked about the trade-offs in
paralleling power Mosfets, particularly driving the Gate
capacitances. Practically speaking, we are talking the
Gate-to-Source and Gate-to-Drain capacitances.
As we parallel devices, we linearly increase the transcon-
ductance, Cgs and Cgd of the parts. Neglecting Cds, the
amount of current it takes to drive the Cgs is proportional
to Cgs and inversely proportional to the transconductance.
There is a considerable cancellation which helps out when
paralleling devices.
The Cds does not go away and remains proportional.
When you look at the spec sheets on these devices, you will
see typical figures quoted, but at Vgs of 0 volts, which is
not typical of the conditions we will see in a linear amplifier.
For the IRFP240 and the IRFP9240 we see a Ciss (total input
capacitance) of 1300 pF and 1400 pf respectively. For the
reverse transfer capacitance Crss the figures are 93 pF and
140 pf respectively.
In linear operation, though, the numbers are different.
Let's take an example of a complementary follower output
stage using 4 parallel pairs of IRFP240 and IRFP9240 with
.47 ohm Source resistors and biased at 100 mA each (400 ma
total).
By carefully measuring the Gate current of each device at
8 volts rms into 8 ohms (1 amp rms) at 1 KHz, 10 KHz, and
100 KHz we can measure the total input capacitance. By
performing the same experiment without a load, we can separate
out the Cgd.
Under these conditions the total input capacitance of the
IRFP240 is about 75 pF and the IRFP9240 is about 60 pF.
Without a load, these figures are 45 pF and 35 pF respectively.
So if you're driving an 8 ohm load with 4 pairs of these
devices, you can estimate your apparent output stage
capacitance at (75+60)*4 pF = 540 pF. Keep in mind that you
won't get 135 pF if you try to drive the 8 ohms with just a
single pair, as the Cgs will will have to be charged to a higher
voltage to make up for the loss of transconductance.
total).
out the Cgd.
Thank you for sharing.
May I ask one question.
Suppose I use ONE single pair, but increase the bias to 400mA per FET, and at the same time reduce the source degeneration resistor by a factor of 4. Assuming of course that dissipation is not an issue, for the sake of the discussion.
At such "low" bias currents, one can count on that transconductance is roughly proportional to bias (quadratic region), i.e. 4x per FET compared to 100mA. In which case I would expect the voltage required to drive the gate to be comparable to 4 pair @ 100mA. Would I then not get close to 135p, give or take 20% ?
Patrick
Patrick
I've been working (playing) with the F4 in the sim, so I thought I would see what Pspice say's about these examples.
All numbers are Pk, not rms, not Pk-Pk
In the tradition of First Watt, I set-up a 4V sinewave Output, into 8 ohms (1 Watt Pk), with an F4 looking circuit that contains 4 pairs of IRFP240 and 4 of IRFP9240. I Also did the same for a circuit with only one pair of outputs. The 4 pair of outputs were biased at 100mA Iq ea. with .47 ohm Rs and the single pair circuit biased at 400mA with .1175 ohm Rs...
Is this the circuit in question Patrick?
The 4 pair circuit measures .083% THD @1kHz. The Gate current for each N FET measures about 6uA (Pk) and the Ps about 5.5uA.
The single pair circuit measures .028% THD @1kHz (mostly 2nd harmonic). It's gate current is about 6.5uA into the N gate and 6.3 into the p channel device.
Hmmmm
I don't see a big difference there (as patrick said "give or take 20% ?")
I suppose a higher frequency may have been a more appropriate parameter to use here???
But, from my previous experiance, the THD numbers are very proportional to the low bias currents. Notice the single pair circuit has less THD??? It has 4X the bias current/FET.
Being not unlike other DIYer's, I also did the same sims with a 20V Pk output. Note, that we are now entering Class AB territory.
The 4 pair circuit measures .092% THD @1kHz. The Gate current for each N FET measures about 30uA (Pk) and the Ps about 28uA.
The single pair circuit measures .165% THD @1kHz (including 2nd, 3rd, a little 4th, 5th and 7th). It's gate current is about 32uA into the N and P gates.
More questions???
Hmmmm
More questions???
the irf hexfet shows rather low combined input capacitance
according to Nelson first post investigation
in a real circuit
the resulting input capacitance is something like 10% of Ciss data
Question1.
is this a value we can use as some 'rule of the thumb'
for most HEXFET / Vertical MOSFET
Question2.
for most LATERAL MOSFET, too
Reasoning that ... even lateral mosfet with their lower Ciss data
should maybe show some 10% ONLY in a real circuit.
I am most interesting of True Class A complementary operation.
As I now post again, in Pass Labs
regars
lineup
in a real circuit
Question1.
Question2.
regars
lineup
Naturaly, I should have made some irresponsible discloser regarding my post above, claiming all statements were made with honest intent and all, but, I am in no way responsible for errors or actuall circuit behaviour. Rid me of the anti simers and their complaints. In other words, your actual mileage may vary
I did however notice a 2-3% gain loss in the single pair circuit. And, I looked at the model parameters for the 240 and 9240 C values: the N has a Cgs off 1457pf and Cgd of 316 and the P had Cgs of 963pf and Cgd 139...
I might guess the single pair circuit is running out of poop due to the loss of Transconductance at almost no Vds (3.5V in my circuit at 20V out). Or it's approching clipping before the lower source resistance of the 4 pair example.
Well Lineup, I beleive when you try to drive a follower, the Vgs is actually almost no difference with signal. Because the Source follows, the Gate, there is very little difference Gate to Source, hence, very little capacitance is actually being driven . This is somewhat dependant on gain There will be a larger diffrence in Gate to Source voltage with lower gain devices
The Gate to Drain voltage though, does see a large change with signal and you are driving it like a capacitor plus some other effects
So, without going into deep math, might N.P. straiten me out Or maybe there is a Thumbnail calculation ???
Thx
Thx
flg said:Thumbnail calculation ???
For Cgs, these figures are for apparent capacitance, not the
actual capacitance.
If the total input capacitance looks like 75 pf and the Cgd comes
in at 45 pF, then the apparent Cgs thumbnails at 30 pF
Into 4 ohms, it will thumbnail at 60 pF.
Into 0 ohms I believe it will come in around 500-600 pF, on the
order of half its rated Cgs.
Well, I guess I will try to calculate the actuall C from my sim machine, just for fun. Although, I'm not familar with the method N.P. was speaking of above. measuring 1k, 10k, 100k ??? I would use a square wave signal and calc from the rise time dV/dT and I. Wouldn't that method work.
EUVL said:Suppose I use ONE single pair, but increase the bias to 400mA per FET, and at the same time reduce the source degeneration resistor by a factor of 4. Assuming of course that dissipation is not an issue, for the sake of the discussion.
It seems logical that you would see that. The potential flaw would be that the
transconductance might not be truly proportional to the bias current. It's
my experience that it's not, so I expect that you should add that 20% rather
than subtract.
For the sake of understanding, and ignoring subjective sonic imprresion for a while.
So in the follower circuit like F4, by using a single FET to replace the 4 in parallel, and then take away the heat dissipation by using a cascode of say 4x IRFP240s in parallel at say 5V Vds of the single follower device, I would get a roughly 3 times (or perhaps more because of the cascode) increase in bandwidth ?
Patrick
Patrick
Probably not quite. First off, the F4 uses 3 devices in parallel, but setting that
aside, the capacitance will go up dramatically with a 5 volt Vds.
Let me emphasize that all of these are barely thumbnail estimates. If you
really want to know, it's best that you hook it up under the conditions of
interest and see what the real figures are.
AndrewT said:does one monitor the gate current by measuring volts drop across the gate resistor?
Will the meter impedance modify the circuit currents when connected?
An isolated high quality AC voltmeter will do the job.
I'm wondering how big is the gate resistor?
If you are measuring the 35pF value at 1kHz & 8V RMS , even with a 1k gate resistor:
V=IR
V = I * ( 1 / 2*pi*f*C )
8 = I * ( 1 / 6.28k*35p)
8 = I * ( 1 / 220n)
I = 8 * 220n = 1.76uA
If the gate resistor is 100ohm, we will get 0.16mV of voltage.
A good 5 1/2 digit handheld meter like Fluke 187 has resolution down to 1uV, can still be useful.
A good 6 1/2 digit benchtop meter like Agilent 34410A can do 0.1uV, will be even better.
But my worry is that, with the 8V RMS Common mode signal, and such small voltage to be measured, is the ISOLATION good enough to be trusted?
A check into the Agilent user manual and I found something.
The common mode 8V rms signal will pass though Ci and generate voltage on the gate resistance which we are measuring (= Vtest here).
Since Ci is 200pF, our calculation will give us 200pF even if the actual gate capacitance is 0pF.
So obviously PASS is not using the Agilent bench top meter.
Handheld meter might help have better isolation to ground and have lower Ci figure, but I'm not sure how much better.
So I'm a bit unsure how well a isolated voltmeter will work to get the actual gate capacitance.
- Mosfet Output Stage Capacitance
