steen , ya lazy danske .........
ya like shinyy ?
you remember when it (almost started ) - in days of NS10 cloning ?
edit :
btw , how Shiny works :
http://www.diyaudio.com/forums/showthread.php?postid=1588700#post1588700
ya like shinyy ?
edit :
Zen Mod said:steen , ya lazy danske .........
ya like shinyy ?
edit :
Yeah, it looks great indeed ZM. I think this will be great with the D1. I am looking forward to see what Zei can make of it, regarding the board.
Oh, and I am not lazy. Apropos the NS10, I am finetuning a very delicate circuit right now.
Combination of NS10 and the B1 in same case. Selectable gainstage or buffer, in the same preamp. Pretty nifty
which version of NS10 and which version of B1 ?
Antonio's :
NS10 linestage pcb
The B1 is a slightly modded version, being fed by a shuntreg, with only filmcaps between reg and buffer stage.
The NS10 also got its rail 'lytic's ditched.
It all sounds extremely promising.
steenoe said:
Antonio's :
NS10 linestage pcb
so - NS10 with single rail supply , same as B1 ...... I suppose ?
steenoe said:Yep, that's correct. I wanted the two kept close to the originals, and to keep each other company. They will both be fed with just under 24V singlerail supplies.
you can feed them with one Shiny , sorta bastardized - one prereg and CCS , then separate darlington shunts for each of them
Re: power supply
Yes, i might try that. It's the sort of approach that would be nice for the D1.
The supply is very much like this one:
Toole shuntreg
jameshillj said:Steen,
Your final p/supply cct?
Toole shuntreg
Re: Re: power supply
I like it
steenoe said:
I like it
- Pass D1 I/V Stage PCB
