Pass D1 I/V Stage PCB - Page 18 - diyAudio
Old 28th April 2009, 07:20 PM   #171
Hi there! I build me the IV stage in an parasound 1500 dac. Its hardwired. I connected the board to the pcm63PK and measured on the input 965mv and the output is drifting between 10mv and -4mv. Should I use the cermet pots to bring the input down? I connected the jumpers. Before I did that, offset on in and output was drifting from 60mv to 45mv on the inputs and outputs, but after an hour offset was at all points 0 mv, and there was no music. The cdplayer locked. Can I give it a try? Or will I destroy something. Grtz Teake
Old 29th April 2009, 09:28 AM   #172
zei is offline zei  Sweden
Hi.
You should trim it to 0V on both inputs.
According to others it might drift somewhat at first before the temp is steady.
/JZ
Tala är tiga, silver är guld
Old 29th April 2009, 04:03 PM   #173
it possible to use this I/V stage for tda 1545?.
and can any one give me the D1 shematic?
thans
Old 2nd December 2009, 02:10 AM   #174
Just got two of these boards from another member.
YUNICK do you still use the d1 with buffalo 9008?
How is the sound?
What were the values you finaly went with?
Old 7th September 2016, 05:26 AM   #175
vizion is offline vizion  United States
Hello,
Can someone share the schematic for the original D1 I/V output stage with a single Mosfet ? This link isn't good anymore: http://www.passlabs.com/pdf/d1-srv-man.pdf
Thanks.
Pass D1 analog stage ctong Pass Labs 3 3rd November 2007 09:50 PM
Pass D1 I/V Stage Layout mozfet Pass Labs 6 24th February 2005 11:51 PM
Pass D1 output stage. pro Digital Source 21 11th June 2004 10:45 PM
Copyright ©1999-2017 diyAudio
