Some other Source Follower Configurations
Old 25th August 2008, 09:14 PM   #11
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Thanks, Patrick
Old 25th August 2008, 09:39 PM   #12
EUVL is offline EUVL  Europe
You're welcome.
I hope you don't mind me posting it here, and that you like the current sensing circuit, inspired by your Aleph CS patent.
Patrick
Old 25th August 2008, 10:07 PM   #13
The one and only
Of course if you're dealing with high current, it becomes a virtual necessity.
When you're driving 10K, I've been able to tweak circuits with just two
2SK370's (one as a CCS) and no additional parts down to 0.0004% thd
+ noise at 2 volts. It doesn't leave me with a burning desire for improvement.
Old 25th August 2008, 10:23 PM   #14
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by EUVL
You have unfortunately posted the wrong layout. This is the old layout of the DAO follower without the Taylor CS. The one in the Power Point includes add-on components to turn the old layout into one with Taylor.
just used you latest ZIP
if you have the wrong layout in the ZIPPED powerpoint
it is nothing i can do about it .. is there?
Regars
lineup
Old 26th August 2008, 04:14 AM   #15
> When you're driving 10K, I've been able to tweak circuits with just two 2SK370's (one as a CCS) and no additional parts down to 0.0004% thd
Agreed. And I did mention the motivation for the alternative circuits in the article -- driving loads (e.g. passive filters) 1k or below.
> if you have the wrong layout in the ZIPPED powerpoint it is nothing i can do about it .. is there?
Just to be sure it wasn't my mistake, I downloaded the zip file from the forum just now, opened it, made it full screen, and printed that into a jpeg (sorry for the poor resolution).
And this is how it should look (see especially bottom left corner) !!!
Nothing wrong with the ZIPPED powerpoint as far as I can tell, probably something with your computer ? Or you are using some Windows Office equivalents ?
Patrick
Old 26th August 2008, 09:48 AM   #16
steenoe is offline steenoe  Denmark
steenoe's Avatar
This one for Steen.
Patrick
Thank you very much, Patrick Cant be easier to modify the DAO with that drawing handy. ( BTW I didnt think that I would ever consider modifying the thing )
Your writing is hotstuff, thanks for sharing.
Old 26th August 2008, 10:17 AM   #17
Steen,
I sent you a PM yesterday concerning boards.
Did you receive ?
Patrick
Old 26th August 2008, 11:34 AM   #18
steenoe's Avatar
Thanks for the mail.
It had ended up in the spamfolder (In good company I might add; Paris Hilton, Britney Spears and CialisViagra and the likes )
Old 27th August 2008, 03:48 PM   #19
A brief update on the DAO with Taylor CS.
I have done some more optimisation using measured data from real devices, with the following adjustments to resistors values :
R1 750R (use 1k trimpot to adjust DC offset)
R2 4.7R 3W
R3 4.7R 3W
R4 41R (= 2x 82R //)
The distortion at 2.6V output into 60 ohm load (AKG 701) is compared to the original DAO Follower :
DAO vs w Taylor
Gain 0.926 0.959
2nd -89dB -67dB
3rd -87db -110dB
4th -99db -120dB
5th -121db -143dB
6th -151db -174dB
7th -188db -206dB
One can argue how accurate these values are, but IMHO a general conclusion can still be drawn.
If you want minimum total distortion, then the original DAO is already very very good. And the Taylor brings nothing extra. But if you believe in weighted spectrum. then look at the difference between the two from 3rd order distortion and onwards.
I know which one I would choose, but hope that Steen will give us a subjective comparison before long.
Patrick
Old 27th August 2008, 04:14 PM   #20
audiotux is offline audiotux  Germany
Hi Patrick ,
is the Taylor CS possible with
sureaMBs version of the Dao?
(see the Dao thread)
he had used 4 Lovoltechs .
Greetings
Jürgen
Some other Source Follower ConfigurationsHide this!Advertise here!
Source follower and common source output stages slogan2112 Pass Labs 2 9th October 2008 08:19 PM
Bootstrapped FET source follower ? ash_dac Solid State 11 14th November 2006 08:19 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 12:54 PM
Source Follower Enlightenment SteveS Pass Labs 3 20th June 2002 09:58 PM
