Some other Source Follower COnfigurations - Page 43 - diyAudio
Old 13th December 2012, 03:42 AM   #421
EUVL is offline EUVL  Europe
I started a new thread on the DAO SE here :
The DAO SE all-FET Class-A ZGF Headphone Amplifier
Patrick
xen-audio.com
Old 7th March 2013, 01:02 PM   #422
Lightbulb again
inverted source follower:
I would like only remain that it
has good linearity,
high input impedance,
~270mA bias,
negative thermal coefficient for fets
and is so simply...
do you know other followers running @swing 30V with distortion ~-150dB?
regards, Pawel
Old 8th March 2013, 03:06 AM   #423
The Dastardly Dad of Three
Not sure if im doing sthg wrong but i tried to sim using your asc file and get strange results .... see attached pic ...
Old 8th March 2013, 05:53 AM   #424
did you have and use cordell-models.txt like attached?
regards, Pawel
Old 8th March 2013, 06:39 AM   #425
yeap...i got mine off his webpage I'll try using the one you uploaded instead..
Old 8th March 2013, 07:10 AM   #426
wait,
today I got this without the changes in asc...
I do not understand...
will keep you informed about the mistakes
regards, Pawel
Old 8th March 2013, 07:32 AM   #427
Guys
it looks like the circuit has got the gain during the night
(250mV at the input)
sorry for inconvenience, I have no idea why the circuit's behavior has changed, I will try to find and correct the mistake
regards, Pawel
Old 8th March 2013, 08:40 AM   #428
Default The explanation:
in post 422 I clicked directly V1 voltage source...
and that was the reason of amazing low thd result...
in real life this circuit has positive feedback and act like voltage amp, not clear follower
do not send me to for this
regards, Pawel
Old 8th March 2013, 09:07 AM   #429
Glad you found out for yourself.
Patrick
xen-audio.com
Old 19th June 2013, 11:14 AM   #430
Thumbs up this time I have checked
this is clear inverted follower with voltage sources instead of big caps at the input to let ltspice make good calculations/simulation.
thd:
N-Period=1
Fourier components of V(vout)
DC component:0.0260207
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 1.000e+03 1.447e+01 1.000e+00 -0.01 0.00
2 2.000e+03 1.492e-02 1.031e-03 -92.14 -92.12
3 3.000e+03 5.350e-03 3.697e-04 9.32 9.33
4 4.000e+03 8.804e-04 6.084e-05 80.75 80.76
5 5.000e+03 4.018e-04 2.777e-05 -149.71 -149.69
6 6.000e+03 8.482e-05 5.862e-06 -113.99 -113.98
7 7.000e+03 5.179e-05 3.579e-06 52.64 52.66
8 8.000e+03 1.114e-05 7.698e-07 46.49 46.50
9 9.000e+03 7.858e-06 5.431e-07 -115.42 -115.40
Total Harmonic Distortion: 0.109745%
regards, Pawel
Source follower and common source output stages slogan2112 Pass Labs 2 9th October 2008 08:19 PM
Bootstrapped FET source follower ? ash_dac Solid State 11 14th November 2006 08:19 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 12:54 PM
Source Follower Enlightenment SteveS Pass Labs 3 20th June 2002 09:58 PM
Copyright 1999-2017 diyAudio
