Some other Source Follower COnfigurations - Page 21 - diyAudio
Old 29th September 2010, 02:12 AM   #201
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Does it have enough low bass? They must be more dynamic than 300Ohm 600s because 50 Ohm, that comes with current.
Old 29th September 2010, 02:36 AM   #202
pidesd is offline pidesd  Canada
pidesd's Avatar
dont know if you mean low bass quantity or bass extension...
i believe, with my ears, that the bass is not at all overly or under emphazise, but i can assure you you that i already heard pretty low bass notes. and the bass can be quite impactful, almost on par with grados grado if driven properly. it doesnt sound quite as full as the k701, so they might not be the best for bass oriented music or orchestral performances, but overall i find the bass accurate but not as natural and extended as the k701 but definitely more extended than grados. a recabling also helps the bass performance a lot.
edit: i did not compared to hd600, but i ve never heard the hd595 begging for a break, even with the heaviest music
Old 29th September 2010, 05:36 AM   #203
qusp is offline qusp  Australia
qusp's Avatar
if you can find them, it sounds to me like the grado HF-2 would be a perfect fit for you and this amp. they are like grado and denon D5000's lovechild. seriously excellent headphones. I dont like grados normally, even the GS1000, bass is lacking, high end a touch grating and too midcentric for me; not so with the HF2.
I spend a lot of time listening to headphones and modding them as part of my work, the modded D2000 is almost there at the level of the D7000 stock and well above the stock D5000 IMO, no point modding the D5000 if you are replacing the cups, sorry forgot, no modding. mine are partial mod (balanced, pads stuffed, cups damped and frame partially damped), full mod sucks too much of the fun out of them.
well yeah the HF2 would work well, you could even buy the D2000 and use them as is until you get back, then mod them. never heard an AKG I liked, even through pretty serious headphone gear I just cant connect with them, technically sound but soulless IMO, all but the highest priced audio technica are the same for me, I like the T1 (and its sexy as hell!), but below that I dont like them, nothing visceral about them. Senns HD600 do not have to be that one step back, balanced with a good amp they are excellent and dynamic sounding headphones, quite comfy too. 650's on the other hand I dont like so much.
to reiterate based on your words I would say get the HF2 if you can and they will also become a collectors item if you look after them.
but yes on te other hand, try as many as you can, if you had time and there was a remote possibility it might happen, I would suggest going to a headfi meet to try out some more unusual stuff before you buy, and realistically you wont find HF2 anywhere but there and maybe Ken Balls shop to demo, you would have to just buy them unheard. even listening in shops only gives you an inkling of what they will sound like at home, the amps supplied in shops are usually not up to the task, but it should give you an idea on flavor.
but then suggesting someone go to a headfi meet is an evil suggestion for your wallet
Old 29th September 2010, 10:29 AM   #204
could you explain your reasoning?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 29th September 2010, 10:57 AM   #205
qusp's Avatar
I actually found the 595 to sound like crud compared to 600's
Old 29th September 2010, 11:07 AM   #206
Banned
Has anyone considered whether a current source amp eg F1J or F2J would make a good headphone amp?
Old 30th September 2010, 08:47 AM   #207
Banned
Default apples to apples
Due to the fact that manufacturers can't seem to agree on how to publish Headphone sensitivity. I have put together more meaningful data for the headphones previously discussed.
If there are mistakes please let me know, and I will update it.
Anyway see the attachments for the results.
Old 30th September 2010, 10:32 AM   #208
Salas's Avatar
Hi Andrew,
Based on my subjective experience that most low impedance headphones tend to create a better sensation of bottom register presence and mid bass fullness when the drive is right, I have thought that it relates to the way their manufacturers take advantage of the extra current VS high impedance headphones in the motor design. Given that BL is Tesla meters related to current and Force Factor is BL/MMs when they would not add as much coil length to higher impedance motors that would have a strong impact on MMs for same BL, or much larger magnets due to size and mass of average cans, then they must be using higher resistance coil wire mainly. That would impact FF, Qe, Qt. Now, when 600 Ohm cans are a studio standard so to use many in parallel in the foldback mix having also EQ in their hands and strong dBV pro outputs, no problem. Using low impedance headphones, especially where there is a high current buffer drive hence the distortion is kept low, is best not only for sensitivity without extra voltage gain stage between source and buffer, but also utilizing the more subjectively ''full'' low Z cans variety.
Old 30th September 2010, 11:34 AM   #209
qusp's Avatar
well it doesnt really hold true with grados in general. mostly I find they are a bit lacking in that area, well in fact the HF2 is the only exception to that rule IME.
that and beyer DT880 25ohms are not as full sounding as properly driven 600ohms DT880
Old 30th September 2010, 11:41 AM   #210
Salas's Avatar
Many other design factors come to play. Open back, closed back, manufacturers diaphragm manipulation and general voicing, having the voltage output to properly judge high Z etc. All things kept relative I think that higher current gives a better chance to stronger motor, lower Q transducer design. IMHO, YMMV.
P.S. I see 250 Ohm standard and 32, 600 Ohm alternatives in Beyer's webpage.
Source follower and common source output stages slogan2112 Pass Labs 2 9th October 2008 09:19 PM
Bootstrapped FET source follower ? ash_dac Solid State 11 14th November 2006 09:19 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 01:55 PM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 01:54 PM
Source Follower Enlightenment SteveS Pass Labs 3 20th June 2002 10:58 PM
Copyright ©1999-2017 diyAudio
