transformer voltage needed for Aleph 4 or Aleph 2
Old 27th November 2001, 11:51 PM   #21
jduncan is offline jduncan  United States
Send a message via AIM to jduncan
grataku:
I'm also building the aleph 4 (in case you didn't pick that up) ....the heatsinks I'm using are from this link.
http://www.aaaim.com/cgi-local/shop9...HUN.htm#HD9800
They are $35.00 not $42.50 so when it makes a mistake in the cart make sure you note it in comments....
I'm using 2 of these....each of which will be cut in half and mounted side by side (2 halves side by side on each side of the amp)
Old 28th November 2001, 07:00 PM   #22
grataku is offline grataku  United States
Jduncan,
I took a look at those heatsinks before. Are just two going to be enough? I have seen the aleph 5 and it is pretty big (maybe 9x9x9), but I think the aleph 4 is a lot bigger (15x15x15 cube???).
How thick is the base plate?
[Edited by grataku on 11-28-2001 at 02:05 PM]
Old 28th November 2001, 07:51 PM   #23
grataku, I'm reasonably certain they will be enough.
these heatsinks have a *huge* fin area. The baseplate is about 3/8" - 1/2" thick in the device mounting strip...
on the edges it's thinner...
if you're really concerned you could just buy 3 instead....
and mount four devices per half section you cut up.
Old 28th November 2001, 07:54 PM   #24
diy student is offline diy student
I'm using the same heatsinks as JDuncan, but I'm using 4 of them. I figured at the estimated 0.8 C/W per 3 inch section that my sinks should be able to dissipate just over 700 watts at 25 C above ambeint temp. And yes I'm planning on purchasing the Apex Jr. toroid. That's the one I was asking about.
Rob
transformer voltage needed for Aleph 4 or Aleph 2Hide this!Advertise here!
Best PSU voltage for Aleph 5 ? stoN_Cold Pass Labs 4 10th September 2007 10:16 AM
C5 voltage in Aleph 5? bbakota2000 Pass Labs 2 15th March 2004 06:25 PM
Sec. Transformer Voltage for Aleph 5 Zapped Pass Labs 10 7th December 2003 06:33 AM
Aleph / Aleph X PCB Help Needed Michael Rothacher Pass Labs 12 30th June 2003 01:03 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Copyright ©1999-2017 diyAudio
