sucess to make aleph-3 to 105w - Page 2 - diyAudio
Old 5th August 2008, 09:30 PM   #11
The one and only
Nelson Pass's Avatar
Old 5th August 2008, 11:37 PM   #12
MashBill's Avatar
Space2000,
What PS rail voltage are you running to get 100+ watts?
Old 6th August 2008, 12:01 AM   #13
i am running on 45vdc as nelson recomended.
very powerfull as i am using my big speaker 8ohms. if you use 8ohms it will get less heat then 4 ohms speaker.
i tested both. now i found best is 8ohms.
Old 6th August 2008, 12:05 AM   #14
i have question for this amp. is this single ended or push pull?
** This amp can triger to class AB, if its goes wrong?
Old 6th August 2008, 02:31 AM   #15
The one and only
The gain devices in the output stage are single-ended, but the
current source feeding them is modulated to provide 50% of the
output variation. The closest topologies are the SEPP and SRPP
topologies from the old tube days.
Old 7th August 2008, 04:56 AM   #16
having some problem, when i use two channel as R-L. its like cliping sound comming with it. at first i used one transformer for two channel now even i tested using indivisual transformer power supply. still having same problem, if i use only one channel its working fine. when i use two channel R-L then cliping sound comming.
how can i solve this?
Old 7th August 2008, 05:41 PM   #17
The one and only
What do you mean when you say "two channel as R-L"?
Old 7th August 2008, 09:52 PM   #18
thank you nelson,
R-L means Right and left channel.
Old 8th August 2008, 01:12 AM   #19
MEGA_amp's Avatar
What size capacitors are you using in the power supply? To me, it looks a little undersized. If you are using it single-ended, you need to ground the negative input too.
Old 8th August 2008, 05:53 AM   #20
i used 4700uf X 20pcs on each psu so total 94000uf for + - each channel. two channel is 94000uf X 2. it should be enough right?
i am using single ended....here is the circuit.
Luxman M-05 105W/channel class A legarem Solid State 56 21st April 2011 08:30 PM
Luxman M-05, 105w class A KBK Solid State 6 23rd January 2010 05:51 PM
WTB: Want to sell your ALEPH X or make me one? JZatopa Swap Meet 0 12th July 2006 10:42 PM
Fostex 166ES-R sucess/failures greenie512 Full Range 57 9th March 2006 04:55 AM
Copyright 1999-2017 diyAudio
