Aleph 5 - B&W CM1
Dear All,
Last year I've made two monoblocks of Aleph 5 driven by Aleph P1.7, sound is terrific. But... recently I've changed speakers with B&W CM1. On modest level of listening everything is OK, but little louder looks like drivers will fly away. Is there any help or should I consider building another type of Pass amp.
Can you be a little more specific about the problem? Assuming equal volume, the speakers should behave the same regardless of amplifier if you mean something you can see with your eyes. (Things you can hear are a different matter entirely.)
If the picture I found on the web is any indication, your CM1s are ported speakers. If, for instance, you are using a turntable as a source, ported speakers will give you extreme woofer excursions at the slightest hint of a 5Hz signal; it's just the nature of the beast. In other words, it's not the amplifier's fault and changing amplifiers will not help.
Grey
