Old 27th July 2008, 09:02 AM   #1
rsbay is offline rsbay  Germany
Default Original Aleph P Coupling Caps
Hello,
I had build a clone of the Aleph P version 1.7 with WIMA MKP4 10u coupling caps.
What I want to know is the original type of coupling caps which are used in the
original / commercial design of the Aleph P. Has anyone this informations?
Thanks for your help.
Ralph
Old 27th July 2008, 11:06 AM   #2
Hi Ralph,
the original caps are Panasonic polyester types - series ECQ-E(F).
You can find them by digikey - part number EF1106-ND.
Your used Wima MKP should be a better choice with lower losses - only disadvantage is the bigger size!
Regards Dirk
Old 27th July 2008, 11:07 AM   #3
Bobken is offline Bobken  United Kingdom
Hi Ralph,
A while ago (maybe about a year) there was a thread about coupling caps in an Aleph Preamp and I joined in the discussion at that time.
If you do a search, you should find this, and it may be of some help to you.
Bob
Old 28th July 2008, 06:13 PM   #4
Thanks for the reply.
I start working on a Aleph P clone in 2004 and I read nearly
everything about how to build it. But what I don't know up to
now was the type of the original coupling caps.
The Panasonics can't be so bad, NP also use them in the
X0 preamp.
Ralph
Old 28th July 2008, 06:58 PM   #5
...not only the X0...
also BZLS, X160, X200 and all XA.5 amplifiers...
The information for the digikey part number comes from the BZLS article.
The only dealer I can find for them in germany is digikey.
Easier is to order Vishay/BCComponents series 468 by farnell (farnell number: 1166121).
They are quite the same as the Panasonics with same dimensions, grid and electric strength (only the color is more orange than redbrown :-) ).
I use them in the BZLS.
Dirk
no coupling caps ray bronk Tubes / Valves 2 20th May 2008 07:10 AM
Coupling Caps in Aleph Ono/XOno and Aleph X0 rsbay Pass Labs 12 23rd November 2006 08:05 PM
Aleph Ono and Coupling Caps rsbay Pass Labs 1 13th July 2005 07:42 AM
Original Aleph P1.7 in/out caps bbakota2000 Pass Labs 3 28th November 2004 08:45 AM
What value for the coupling caps? roibm Parts 12 23rd March 2004 05:58 PM
Page generated in 0.08338 seconds (70.57% PHP - 29.43% MySQL) with 10 queries
