Old 20th March 2003, 01:10 AM   #1
karma is offline karma  Canada
karma's Avatar
Smile mosfets
when it comes to installing mosfets on a heat zinc what works better a single screw or 2 screw holes on each side and clamping it down.i wana try clamping it i just dont want to wast my time
if it does not work help
thanks......
Old 20th March 2003, 01:15 AM   #2
The one and only
Nelson Pass's Avatar
Mounting the Mosfets as they were designed is pretty
adequate. I don't know of any manufacturer specifying
otherwise, and you could conceivably run into loss of seal
between the plastic and metal.
Old 20th March 2003, 01:17 AM   #3
Circlotron's Avatar
I like the clamp method because then the mosfet doesn't tend to pull down one end and lift up the other end. The force is more even over the whole of the back of the fet.
/Circlotron - not wanting to contradict Nelson Pass, quickly edits his posting.
For high voltage use it is often necessary to use a clamp to get the required creepage distance. If you are not going to work the fet too hard then using the hole is ok. For maximum thermal transfer I still like a clamp though because you can get the pressure right over the die area of the fet.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 20th March 2003, 01:26 AM   #4
The one and only
Contradict at will
I personally like the aesthetics of the clamp approach, but I think that when you reach the point where you need that "extra thermal transfer" you're probably already on thin ice.
pass/ - likes to stay within 25 watts on 150 watt devices
Old 20th March 2003, 01:37 AM   #5
karma's Avatar
Talking mossfets
i have one screw so ill leave it. wow zen amps run supper hot
whats the life span of a mosfet at this heat? and if i hose a mosfet
will it take the pcb with it?
Old 20th March 2003, 01:39 AM   #6
The one and only
What heat would that be?
Old 20th March 2003, 01:48 AM   #7
karma's Avatar
Default hmm
i dont have a tester but if i ground myself and then touch the fet its to hot to keep my finger on
Old 20th March 2003, 01:53 AM   #8
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
You can reduce the heat with a fan. How hot is a heatsink, can you keep your hand on it?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 20th March 2003, 01:58 AM   #9
Suprise, suprise...
even with a good heat sink they are hot...too hot
Old 20th March 2003, 02:01 AM   #10
The one and only
So how many watts are you running them at?
What mosfets to use? seafire Solid State 18 25th March 2009 09:44 AM
Where to buy MOSFETs? goodas Solid State 26 15th June 2008 08:55 PM
n/p Mosfets vs depletion mod mosfets marcello7x Car Audio 6 4th October 2006 05:01 AM
Why no MOSFETs? Pbassred Solid State 25 1st February 2004 08:06 PM
hmm.. help with mosfets Colt45 Solid State 5 27th August 2002 07:08 AM
Page generated in 0.09234 seconds (76.30% PHP - 23.70% MySQL) with 10 queries
