A30 - Finally!
A30 - Finally!
Old 14th July 2008, 04:42 PM   #11
gema is offline gema
jacco:
http://img172.imageshack.us/img172/2158/img1225asf7.jpg
http://img172.imageshack.us/img172/4287/img1226aja1.jpg
http://img329.imageshack.us/img329/8526/img1227ahk6.jpg
The fun part is that the PSU is just slided into the chasis. A few screws and on you go.
Old 14th July 2008, 04:46 PM   #12
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Beautiful!
Old 14th July 2008, 04:59 PM   #13
Valeriano is offline Valeriano  Italy
Extremely clean build, wow something to learn. thanks
Valeriano
Old 14th July 2008, 05:53 PM   #14
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The audio-porn on demand channel, my kind of thing.
Old 18th July 2008, 01:18 AM   #15
Serge66 is offline Serge66  Switzerland
Serge66's Avatar
Hi Gema,
Congratulations! Very nice work.
I am jealous.
I would like to mention two points:
make sure the Faston connectors are very tight on the rectifier lugs.
If loose, the resistance increases and that will lead to a hot spot/connection. I experienced that in one of my amps. I then soldered the wires straight to the rectifier lugs.
Power resistors should be mounted above the pcb. A gap between 0.25 and 0.5 inch (5-10mm) helps the cooling and will prevent damage to the pcb if the resistor gets very hot. Burnt pcb smells foul. Burnt pcb also becomes porous and moisture can create a path between tracks and pads and create havoc with signals and power supplies.
Enjoy your amp.
Serge
I am now surrounded by autistic people drooling on their mobile phones, tablets... sad
Old 18th July 2008, 01:24 AM   #16
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
A30 - Finally!
An extremely nice looking amplifier.
Congratulations.
Old 23rd July 2008, 08:58 AM   #17
Maybe this little thing will help someone.
I don’t like trimmers of any kind, so in this project I came across a solution for fitting resistors that may be easily swapped with resistors with different values. The catch is in the pins taken from DIL IC sockets.
Old 23rd July 2008, 10:22 AM   #18
Peppe is offline Peppe  Italy
When you find your value, do you solder the resistor on the catch or not?
Old 23rd July 2008, 10:53 AM   #19
Nice job Gema.
What is the band around the toroid made from?
regards Andrew T.
Old 24th July 2008, 07:34 AM   #20
Peppe:
no need to; the DIL pin grasps the resistor's leg quite firmly
AndrewT:
toroidal transformers are wound with feromagnetic tin to minimize magnetic field dissipation
A30 - Finally!Hide this!Advertise here!
Finally got my AT 150 Mlx duderduderini Analogue Source 0 26th December 2008 12:57 PM
finally getting going Spica Introductions 1 20th January 2008 03:57 PM
finally...I am able to say hello to everybody and everyone. groov Introductions 3 28th August 2006 10:44 PM
Finally jpb200 Multi-Way 2 26th May 2004 02:58 AM
Finally, almost done with first IGC officeboy Chip Amps 3 11th February 2004 05:24 PM
